Probably not directly, but some modification might allow for it.
What's it from?
What are the existing diameters?
Any body seen this before? 4 hp engine , can a clutch be put on?????![]()
sorry, but the rest of the shaft is likely 3/4" correct?
Why not just add a spacer (keyed) to regain the diameter and make it a 3/4" shaft again?
What he ^^^ said.
Or a spacer, to lock the clutch, and use the the 3/4"part of the shaft. Unfortunately, the OP chose to only answer 1/2 of my question .
Wasnt even your question for starters, and you just offered up the same solution as itsid...![]()
