Engine shaft
Jersey 08901
New jersey
Any body seen this before? 4 hp engine , can a clutch be put on?????:huh:
anickode
S.E. Michigan
Probably not directly, but some modification might allow for it.
What's it from?
What are the existing diameters?
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
Looks to me that someone made that crank shaft work for something else previously. Too bad that ruins them cranks for the next guy.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
I bet you could change out that crank for pennies on the dollar!! It's really easy to do and we will help you locate the parts and guide you through it. That engine is well worth it. Looks like a Craftsman engine and come to think about it, I've seen that before. Strange set-up for sure!!
sorry, but the rest of the shaft is likely 3/4" correct?
Why not just add a spacer (keyed) to regain the diameter and make it a 3/4" shaft again?
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
Or a spacer, to lock the clutch, and use the the 3/4"part of the shaft. Unfortunately, the OP chose to only answer 1/2 of my question .
