Engine Problem
JROY82
Oklahoma
I am only using the #25 chain because it is what the original jackshaft on the pocket bike had. It is obviously not my preference. I run #41 from clutch to jackshaft. I havent been able to find a #41 or #35 rear sprocket to fit the bolt pattern.
JROY82
Oklahoma
Quick update on the chain issue. Its actually not #25 its like a metric size of #35 so it is decent sized chain but not so easy to find. I apparently have never seen #25 chain and I now see why no one would use it.
ZnsaneRyder
Crazy Guy on a Bicycle
FL
Second or 3rd time I've read posts about chain breakage.
What's going on here?
I believe it's because most use don't use a strong #35 or #40 chain, and also probably don't lube their clutch often, so it chatters and engages too hard and puts considerable shock on the chain.
A dry clutch flops a chain around, and makes a lot of noise, and a bit of WD-40 on the bushing AND friction surface before running that day, makes for a smooth engagement & takeoff and by the time it burns off, it still is fairly smooth before needing it again.
Russ2251
AZUSA:Powered by LAWN-BOY
Chain lube works best.
Clutch just needs a couple drops of sae 30 on bushing every few hours of operation. Shoes never need any oil if properly maintained. Clutch should never chatter. Chatter indicates damage from overload.
