Electric Off Road Kart
Mammoth
Durham, CA
I just picked up a Ford Transit van so I can travel with multiple vehicles. I like the idea of having an electric full suspension kart so I can explore dirt roads in the forests and not disturb the wildlife.
Since the kart is going to fit into a van it has to be on the smaller size. I saw a Zyliathor kart and thought one would be perfect for my needs. It can be ordered in several different versions of gas or electric. I wanted a little more power with a lot more range than offered. So I decided to order a Zyliathor clone 63cc gas version off Temu and convert it to electric.
The total for the kart was $640, and it arrived in a crate. I had low expectations on quality, but that didn't concern me because I planned to upgrade most of the parts anyway.
Upon assembly I noticed they used soft rubber plugs to center the a-arms which is probably fine at 18 mph, but not going to suffice at 70 mph. In order to remedy this I milled some steel inserts to press into the tubing.
I cut the steering handle off and mounted some regular handlebars.
The two short rods on the rear 4 link are mounted to the front of the axle housing which can cause the axle to roll under acceleration or braking. It would be better if there mounted to the top of the axle housing.
Decided to fix it while I'm upgrading all the parts.
Built some adjustable tie rods in the process.
Mammoth
Durham, CA
The shocks that came with it were not shocks at all, they were just springs. I ordered mountain bike Fox Float X Air Shox which are shorter, but have more travel. All the mounts had to be altered so they could fit.
The rear upper mount 12mm bolt hole had to be welded so I could drill a smaller 8mm hole. The new shocks use 8mm bolts.
The bottom mount had to be cut off and built taller to work with the shorter shock.
Rather than weld the A-arm mount 12mm hole and re-drill, I drilled an 8mm hole below and ground off the rest. I had painted it white which ended up getting ruined. I will have to sand blast and repaint again.
The upper front mount had to be cut off, then cut in half so I could roll it down to make up for the shorter shock.
Filled the gap with a pie shaped wedge, and the bolt holes had to be resized to 8mm as well.
Mammoth
Durham, CA
Surprisingly I didn't come across Pinkpanda3310. I searched all over looking for any info or videos.
The shocks are normally $400 but I found them on sale for $129. I like these because I can adjust the air pressure to match the weight of the kart.
Made some shock guards to block any rocks that get kicked up from the front wheels.
I had to make a cradle to hold the battery. It ended up simpler than I had envisioned.
The battery I chose was built by Spiderbatterysystems. It's 84v, 45Ah with Molicel P50B 5000mah batteries. I wanted to have a good range without carrying too much weight. This battery at 28 pounds was the right balance between weight and distance.
Mammoth
Durham, CA
I ordered a hydraulic disc break conversion kit as an upgrade to the mechanical brake that came with it. The conversion kit had a single piston caliper which is a design I don't really care for, so I swapped it with a dual piston caliper. I had to make this bracket just to hold it.
The red caliper is what came with it, the black one is the single piston and the gray is the dual piston. Should be able to lock the tires up pretty good.
Upgraded to race kart hubs and wheels. Stock wheels are known to crack.
Replaced all the cast aluminum Heim Joints with chromoly. I don't want one to break way out in the woods.
Had to make a mount for the FarDriver ND72680 controller.
Welded it behind the seat, which also adds support to the back of the flimsy seat.
The motor is a Sotion GST11 which is capable of 11000 RPM. It's geared to 68.7 mph.
I upgraded the #35 chain to a 420 o-ring chain in an effort to reduce noise, and give it more strength. Im going overkill with the parts to make it indestructible.
The stock tires are made of some cheep rubber so I ordered a set of Carlisle dirt tires with the same tread pattern. The tread is twice as high and I mounted them to some two piece aluminum wheels. Now I can switch back and forth between dirt and street.
pinkpanda3310
Holy macaroni, what a build ! You must be taking inspiration from 'Daniel's Adventures'.
I converted a G63 kart but not too this degree 🤩
Your mud guards for the shocks are cool but don't wear shorts while riding... don't ask me how I know 🥴
I wasn't aware the stock wheels could crack, never seen or heard of that before. Or the heim joints, I've bent one after a hard hit. Bent it back and it's been good so far. I think John Perrel (fb) has worked out an upgraded rear axle if you're inclined, i don't know much about it in all honesty. If you use the stock axle just be sure to use long keyway steel. I'm in the process of maintenance due to the keyway getting chewed out. It's been a bit over a year of use though.
The only other thing I can suggest is comfort. Get a footrest extension and/or a cushion for the seat. I use a wedge shaped cushion and it makes a world of difference for comfort.
pinkpanda3310
One other thing to mention on these karts is the caster. They often have 0° caster. A couple of people have re-welded the mounts of the lower wishbones further forward. It doesn't need much, maybe 1/2". Since you've got metal bushings in the suspension just double check the geometry and travel don't bind up your flash shocks.
Mammoth
Durham, CA
Yeah I watched Daniels videos. Lots of good content there.
Went all through the groups picking up info. That's where they talked about cracking the weld on the wheels, but they are putting some big horsepower to them.
I did swap the rear axle to a BMI axle because it's a little wider which works with the aluminum hubs. Otherwise the stock axles were reported as good to go.
That caster seems hit and miss. Some people have reported trouble at higher speeds, and others say no problem. I will have to run it and see what happens.
I will be working on the electronics this weekend. Had to order a display, a Bluetooth module and some 6 awg wire. Im sure there's more I will have to figure out along the way.20261004_110054.jpg
pinkpanda3310
I'm not a fan of most displays. I think my preferences differ slightly than most people. I don't like guages that show high>low, I want the actual numbers. Priority on
1. Volts
2. Amps
3. Odometer and trip metre
4. Speedo
I have the Worthless Controls app and I find it easier to understand and use than the fardriver app. One thing I wasn't aware of in the beginning is the fardriver controller was not running at full power with factory settings.
Hey Mammoth,
Nice kart
...& upgrades too (& pinkpanda...too) :thumbsup:
Maybe a PZEM-051 Power Meter (~$25.00 on eBay) would be helpful
It displays the
...Voltage (level of the battery pack)
...Power (in Watts)
...Current (in Amps)
...& has a re-settable Energy counter (in Watt Hours) too
This video shows the power meter...quite often
Mammoth
Durham, CA
Thanks everyone for the advise. This is my first time wiring an electric vehicle, and there's lots to figure out.
It was recommended by E-conic Cycle that I get the Chaojie display. Then I ordered a few plug and play harnesses from Electric Moto Family in an effort to make it easier to wire. Trying not to get overwhelmed and bogged down by wiring.
Had to make a mount for the display. I was already going to make a buffer between the hold down strap and the battery so I combined the display bracket and strap buffer into one.
