driving me crazy,tecumseh
wajjlj95
Vicksburg,MS
I got this gokart used for the little ones.Tecumseh 5hp OHH50 engine.I pulled the carb and it was in very bad shape,so I bought a new one.Have installed it and it will crank on first pull,but will only rev up very little then dies.This is the case on and off the blocks.
wajjlj95
Vicksburg,MS
It only has an idle speed adjustment.It will idle fine,all day.When giving it gas it will rev up a little,keep going with the gas and will die.
wajjlj95
Vicksburg,MS
I used the owners man... to get the part #.Ordered it from outdoordistributors.com.Looks and fits just like the original.I'm not sure.
solomon
ca
sounds like its 1 of these 3 thinks, lean,rich,air leak.
Did you replace the intake gaskets?
wajjlj95
Vicksburg,MS
linkage is as it was when i got it,No choke just primer button,did replace the carb gasket but not the intake.spark plug is black and dry
slideways
Do you have the filter on? Both of the screws need to be in the carb because one has an air circuit behind it.
Try to slowly pulse the primer as you try to rev it and tell us what happens.
wajjlj95
Vicksburg,MS
I had to take the tank off to replace starter rope. I drained and rinsed out the tank w/gas when I first got it. Yes,it did run fine till it sat up for a year. After I got it,changed oil,starter rope,gas,still would not run,took off carb n it was very gunked up,thats when i put the new carb on it. Now it will start on first pull after two pumps on the primer button,will idle all day if I let it. But will only barely rev up when opening the throtle(fast or slow) then dies.
wajjlj95
Vicksburg,MS
when I pump the primer with the throtle open it will rev up ONLY but goes back to bogging down or choking after that shot of gas is gone.
Linksep
Twin Cities, Minnesota
Main jet is plugged or out of adjustment, as soon as you add air it goes lean and dies.
Other far less likely options are your needle valve is plugged or you're not getting fuel to the carb (hose kinked, filter plugged).
wajjlj95
Vicksburg,MS
Another thing,the cable from the brake to the governor arm was broke. I'm thinking this is why the throtle stuck on `em. I changed it as well.
wajjlj95
Vicksburg,MS
I have adjusted the float up and down several times with very little to no results,it's currently back to manufactors specs.
solomon
ca
defiantly rich, can you take pics of the carb? Also how's the exhaust on this thing?
