Budget GoKart
Aka a kenbar
Well I'm cheap had no money or parts to fix the budget go kart so I had the idea to fix this one since I have the parts. And I figured I'd fix 2 karts with one go. So I started with stripping the junk off chopping the exhaust up and removeing the redneck "features". And I removed the Briggs 5hp that I was swapping onto another kart took the band brake off the 25$ mini bike I have. Chopped the scrub brakes off and converted it to drum replaced the studs with bolts in the hub and drilled a hole in the engine plate for the band. Rebuilt both back slicks with used inner tubes that hold air and I need to read drill the hole for the band. And now I'm flipping the steering from back to front and unbending the tierods. I replaced the bolt in the steering wheel and flipped that upside down. Still not done with everything just small things are done.
Plans:
Finish fixing the steering
Cut the floppy front off to make it look like a rupp
Move the pedals back behind the steering and attach them to the engine and brake
Smaller front tires (not sure yet)
Seat
Paint
Stickers
Predator 212
Wing (it has a wing mount )
Plans:
Seat
Paint
Stickers
Predator 212
