anderkart
I found some info stating that pump was sold in 2 versions:
One made to fit engines with a 3/4 output shaft,(although it didnt say if they were tapered or keyed PTO's)
And another version sold to fit engines with 5/8" output shafts with a threads at the end of the PTO.
You could try unscrewing it with a pair of channel lock pliers or vice grips. You'd just need to feed some clean rope down into your spark plug hole to stop the engine from turning over...
Or you could try calling that phone number on your pumps tag, I'd just tell them your pumps model number, and that your replacing your engine, and ask for advice on how to remove your pumps shaft adaptor from your old engines crankshaft.
