greaser
new here
I am guessing supports will be needed at least at the bend and the ends.
Yep if it's higher on the drivers side it should level out when I am in it.
Any air that gets sucked in will go to the top of the rad, the lower tank will be redundant - might as well put a solid cap on it....
In this case, you would need to make sure you have 2 good caps, one for the radiator, and one for the the reservoir. I would burp the coolant form the radiator cap, as it will be the highest point in the system and should bleed out without issue.
