Dingo rebuild
Dingocat
Broke
NE Ohio
Some backstory: I got this kart almost a year and a half ago, really my grandparents did. It was down in North Carolina. I'm in northeast Ohio, ~500 miles away. It sat there for multiple months and on a trip down there we stripped it down and brought all the parts up. Rusted out back wheels with dry rotted tires. Rusty torque converter, shot bearings and a worn out sprocket.
All the parts sat for months where I'd use them for other projects when I finally started getting them prepped to go back together, welded ground and painted the rims and put tubes in the tires.
Now I've been working on sanding the frame now that the floorpan is off so we can weld a new one on.
I got parts as a birthday gift, so springer spindles to replace the worn out ones as well as an intake for the Gx 160 that will go on it. Just today I got the other back tire mounted with the help of a friend and mocked up where the axle would be and also an engine, subaru as a substitute for the gx160 right now or a kartfab style big block, which will be more modification/money/time/fun.
Sent from my SM-G950U using Tapatalk
Dingocat
Broke
NE Ohio
Looks like you will beat me to a finished dingo! She is looking good!
Thanks! And I don't know, I still have to clean the while bottom of the frame and cut the floorpan and get it all welded, and fix my hubs, plus I don't have a seat and will have to make one from scratch pretty much.
Dingocat
Broke
NE Ohio
And for whenever JT sees this I have the briggs and will be taking the bronda aproach because I needed the carb for the other one.
Smerft85
Southern Colorado
I feel the pain, have to rebuild the 13hp honda, build an exhaust for it, bearings all around, new floor pan, continue correcting the stretch, ect ect ect. Private build off between us jist for fun dingocat?
This looks like it'll be a fun restore. Does the GX160 you have, have a stator so if you wanted to run a light on the roll bar?
Dingocat
Broke
NE Ohio
I tried to bolt up 30 series and it hit the block in all of the "normal" positions. Jackshaft time. And did you have a 30 series on yours smerft? I'd get a 40 series but they're pricey. And my dad is fine with putting the engine on the kart, he'll be doing a good bit of the welding. I'll do some but he'll do most of it. Haven't really started welding yet. and the only neighbor who does this type of thing threatened to call the police on me.
Smerft85
Southern Colorado
Pretty sure it's a 40 series being on a big block, don't thing it even has a belt on it honestly, I pulled the jackshaft and clutch along with the motor. With lots of practice welding becomes easier. For light stuff like karts I can't recommend the Lincoln weldpak series enough, flux core mug and it plugs into a standard outlet. I've fixed stuff on my off road trucks with it and it welds stronger than I thought it could.
Dingocat
Broke
NE Ohio
I left the stuff out for a month and my dad cut and welded on the floorpan. Looks good and is sturdy lol. I was going to do it this weekend too. He did it while I was at work.
Dingocat
Broke
NE Ohio
More work today. Took all the rust off of the front half. Primer. Have to do the rest still but it's looking good.
That frame is seriously pitted!! Is it going to be strong enough in the places where it counts?
I did not notice that.
What’s the feasibility of blobbing on some weld to fill in the pits
and grinding it smooth again?
Smerft85
Southern Colorado
Or cut the old out and place new metal altogether? Otherwise looks like progress has been made, I hope I didn't get him working too fast after offering a friendly dingo buildoff!
Dingocat
Broke
NE Ohio
I don't really have the tools or materials to put new metal in, minus the floorpan. The pitting is in the front and there is bracing. So I'm going to roll with it.
---------- Post added at 11:06 AM ---------- Previous post was at 11:05 AM ----------
And Hellion, the whole front part would need it.
