Diamonite Electrathon America Racer
A bit of progress
Gots a "new" idea :bannana:
...for a "laminated" fiberglass Swing arm ;)
&/so
Ta "work" on it
...I went ahead & assembled the rear wheel :thumbsup:
We gonna be "running" a 13 x 5.00 x 6 ribbed tire :cheers2:
Here is the sprag/freewheel unit & 48T x #35 sprocket :2guns:
Is that tire ribbed for her pleasure? :ROFLMAO:
Of course :cheers2:
I had some issues mounting the tires on these rims :huh::furious2::mad2:
These tires are labeled "tubeless"
...so, they are designed to fit "tightly"
...but, WTF?? :ack2:
Doin' research, some say to use talcum powder ta help the rim, slide into the tire
...but, a whole ~1/8"...yea right! :eek:
After "fighting" with 'em for a while
...I "trimmed" a little bit off
* Not sure if you're supposed to do that :innocent:
...but, I did :devil2:
Tried ta keep the "trimming" nice-n-even, all of the way around ;)
Yup, they fit on there...now :wai:
I wasa/been thinkin' about the monocoque mold, that I built last winter, for Diamonite
Now, that I'ma learnin' a bit more
...it seems the mold, that I made is...just awful :eek:
In a few different ways :(
I ain't gonna even gonna try-n-explain :surrender:
So, "for my next trick" o_O
Ta da :sifone:
Back to the "drawin' board" :surrender: :huh: :cheers2:
I gots some new ideas :idea2:
...& some more boards...too :thumbsup:
Went-n-cut 'em up ;)
Pile 'o wood
After some assembly
Used a plate ta mark/round the upper corners
Roughly assembled into some "ribs"
...on a "kabob" :thumbsup:
* Notice the "skewer"? :unsure:
The "skewer" helps with "rib" alignment
...& will make the whole (upper 1/2) "mold" turntable
...like on a rotisserie :2guns:
Assembled 'er on the "base"
...ta make sure "everything" lines up :thumbsup:
FYI: the "base" is upside down ;)
Um...I made a "covered wagon"??
3D ;)
Small (in front)
...big (in the middle)
...& small (in the rear)
Covered the sides with strips of 1/8" MDF
Used spray foam to "fill in" the gaps
...& help "stiffen up" the wood strip/sides (ta make 'em all "as one") :thumbsup:
* Now, it looks like a boat :mad2:
Base
...upside down
...ta "work on" the "outward facing side" :thumbsup:
The perimeter is the same, as the bottom edge of the "body" plug
...but, the top (actually the bottom) is a ~1/8" smaller
...so, I could make the sides "taper" inwards a bit
The actual top (still the bottom) is ~1/2" smaller
...so, I could really round them edges goodly ;)
This is the front (work still in progress)
This view shows the round-ness
...& taper, that I'm "goin' for"...pretty well :cheers2:
Just like when I made up the FG hoods for American Ethos racer, I'm researchin' experimentin'/tryin' different materials
I have an almost full can of White Rustoleum Oil based paint
* From my experience, a couple of coats of this stuff creates a really durable surface/finish
...much thicker & stronger than standard spray paint
So, I wanted to "see" how well it would work on a FG plug/mold ;)
But, I wasn't sure if :unsure:
1.) Oil based paint could just be applied over new/bare wood
2.) What kinda primer would work with wood & oil based paint
So, I did some researchin'
...& come across/found this stuff called Gesso
Gesso (Italian pronunciation: [ˈdʒɛsso]; 'chalk', from the Latin: gypsum, from Greek: γύψος), also known as "glue gesso" or "Italian gesso",[1] is a white paint mixture used to coat rigid surfaces such as wooden painting panels or masonite as a permanent absorbent primer substrate for painting. It consists of a binder mixed with chalk, gypsum, pigment, or any combination of these.[2]
Gesso is used in painting as a preparation for any number of substrates such as wood panels, canvas and sculpture as a base for paint and other materials that are applied over it.
So, ta seal up this wooden "bottom" &/or "floor plug/mold" I got & tried some :thumbsup:
Yup, it gave 'er a smooth but, kinda chaulky surface (perfect for paint)
Then, after a couple of hours
...I gave 'er a coat of the White Rustoleum Oil based paint :cheers2:
Don't you have a day job? You're the busiest guy I know.
Hey WTR,
Yup, I'm self-employed/drive a tow truck (a little over 30 yrs...now) :sifone:
...& am almost always "on call" :thumbsup:
But
Whilst I'ma waitin' for the phone to ring
...instead of just sittin' around
...or watchin' TV
...I do stuff :auto:
While I'm out driving around (towing cars) I think about
..."what I'ma doin' next" on my projects ;)
or
Pick up any needed supplies
...while I'ma...already out :2guns:
OMG
The more I worked on this "thing"
...the more I dis-liked it
On the "bright side"
...I'ma learnin' stuff :thumbsup:
Like I found that, using 1/8" MDF strips wasn't a good idea
...as they don' hold their shape very well between the upright supports (wavy)
...& they "flex" a lot, when tryin' ta do body work (smoothin') too :ack2:
So, I tried to re-enforce or "back 'em" with some spray foam
...but, found that "spray foam "keeps on tryin' to expand, for several days after application
...& this continual "pressure" actually made the wavy-ness, of the strips worse(r) :eek:
I just didn't like the overall shape either :(
So, I went back to the "drawin' board" ;)
I'ma gonna try-n-use some different materials for the "strips" (1/2" MDF)
...& a bit of a different construction method too :thumbsup:
This monocoque/body/mold will have a bit more 3D "roundness" to the sides
...& the "top"
Both "up & down"
...& from "front to back" too :sifone:
But the big question is will you be able to fit in it?
Hey Denny,
The "nose" is ~36" wide
...the "tail" is ~14" wide
...& the sides are ~20" tall (in the middle)
So, yup :thumbsup:
...everything but the drivers head ;)
Also, all (3) of the wheels will be inside of the body too :2guns:
* The front wheels require/need ~8" (on each side)
...so, with a 36" (nose) - 16" (8" wheel wells x 2) = 20" (of leg room) :smartass:
