electraglide
- Messages
- 167
- Reaction score
- 192
Ok .... so I traced the wires from the dash board towards the engine and all are accounted for. A ( pink/red ) comes from the Key Switch B ( red/yellow ) comes from the starter button. On the Key Switch 4 pin .... pink/red is as mentioned ends at terminal A and voltage regulator, green to ground, black n white to kill switch and I think also goes to the ignition coil, black is shared by lights horn and on/off toggle switch. toggle switch turns on lights. You mentioned that battery pos goes to #1 neg goes to engine chassis ground. Could you please reiterate where A,B,C and D go. I think you said A goes to C with a fuse in between ( what amp ) and B goes to D. ( this pic I labeled different than the earlier one ) Battery is on order. As you said , I may not need the Switch Box but I sure do need those connectors ....... they are just falling apart.
