electraglide
- Messages
- 167
- Reaction score
- 182
I found the wiring diagram by doing a search on Google for Trailmaster mid wiring diagram. The Trailmaster and Hammerhead 80T or Mudhead are pretty much the same machine. Google Trailmaster or Hammerhead, you'll find a bunch of stuff.Karttekk ... thanks for taking the time. I appreciate it. where did you find that wiring diagram. I could use more literature so's I can study up on this Kart. I have the owners manual but that is half written, the other half you have to guess.
Bacon, here's what I do to find those diagrams. If someone has a Manco question, I go to Go Kart Supply and hopefully find the model in question by using this chart: https://www.gokartsupply.com/mancogokarts.htm@Karttekk always comes out with the best diagrams. don't know where he finds 'em. Maybe he'll share his secrets with us peasants...
The first thing I would do is pick up a good 12V test light, it's your best friend dealing with these wires. I would pick up a new key switch, it includes a new key. The old key switch comes out by squeezing two tabs behind it in the dash and pushing it out. I ran into a problem with a new key switch. The wires in the switch didn't match the wires in the harness. I had to push the wires out of the switch and reinsert them to match the harness. no big deal there. Your wiring looks right from what I can tell. It would be easier to see them without the distracting dots. On my kart, the thin red wire is tied into the fuse holder and the voltage regulator plus it fastens to the positive post on the starter. The green wire is grounded to the engine shroud/cover. The black wire with the white stripe connects to the coil wire coming from behind the shroud, it's the stop button wire. Remove that yellow dotted wire from the starter. Does your kart have a powered tail light? Maybe the brown wire powers it if equipped. I'm thinking with a new key switch and key you might be okay. Make sure your battery is good and fully charged. Report back with any updates. I'll get you a picture of how mine is setup in the meantime.Thanks everyone for your input. One problem is that the kart has been spray painted and it's hard to see what colors the wires are. My story continues:
This Kart has been bought and sold several times. When I got it was painted over including some of the wiring so it’s hard to tell what colors they are. Did not get a key either. I know next to nothing about mechanics or wiring, I just go by pictures and labels and use that as a reference. This is what little I know and that might not be accurate. The red traced wire comes from harness to I don’t know what that is. Whatever that is has the + sign on it and that yellow traced wire is just dangling there. Also on whatever that is the solid yellow line wire is connected to the top side of the starter. The green one is grounded to the engine pull starter cover. The blue ( comes from the harness ) and brown appear to go to the rectifier. The brown one also goes to underneath the engine. The purple traced wire is also just dangling there. The white dotted traced wire is connected into the top of the engine.
I tried to connect that + wire ( yellow dotted ) to the positive of a 12v battery and I grounded the negative side to the engine housing hoping that I could bypass the ignition switch. Nothing happened unless I did something wrong. Could be that since I don’t have a key might also be the problem. If that is the case maybe I could jump the 4 pin connector to the key switch but I don’t know how to do that. Don’t wanna short anything out.
Any help would surely be appreciated. Thanks in advance.
