Damien
I figured that it would be best to spray the color, on the kart first :idea2:
...then, give everything a couple of coats of the clear (while I had it mixed up & in the gun). :thumbsup:
But, before that we gotta put some stuff together.
Partial Assembly
Prior to painting, (the black base coat) I assembled some stuff like the steering shaft (because it always seems to get scraped during assembly)
…& then, before the top coats, I assembled a few other things like the spindles & tie-rods (the bolt heads always gets scuffed if I put a wrench on 'em after paint)
yup, then some/a bunch of cleanin' (so dusty in just a few days) :smiley_omg:
I cleaned 'er up, mostly outside then, put 'er in the DIY paint booth
…& gave everything a final wipe down.
Now to get our color shifting "paint" mixed. :thumbsup:
It's basically just "special" powder (magic dust) that ya add to a clear "binder". :cheers2:
The clear that I am using is a 2K (2 component) system.
It's to be mixed @ a 3:1 ratio with the activator (hardener)
https://www.ebay.com/itm/Automotive...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
That would be ~19g. per qt. (32 oz.), ~9g. per pint (16 oz.) & then ~5g. to a 1/2 pint (8 oz.)
I'm gonna try 8 oz. This kart doesn't have many flat areas, mostly bars
...& I only need to put a couple of light coats
I don't want to mix up more than I need (once activated it only has ~4 hr. "pot life")
So, next we need a paint mixing cup, for the 3:1 ratio
...& a scale to weigh the powder. :cheers2:
Well, to end up with ~8oz. of material @ a 3:1 ratio after mixing, we'll start by pouring 6oz. of the clear into the mixing cup
…& then, adding 2oz. of the activator. :thumbsup:
After mixing that mixture well (~2-3 min) I added ~5g. of the "magic dust" & spent another 2-3 min mixing that up good. :cheers2:
Then, I loaded it up into a spray gun & headed out to the paint booth.
While test spraying I accidentally got some on the rims (on the inside side)
...so, I thought what the heck, I'll go ahead & spray the inside side to "flip" or change colors too.
(just to see how it would look) :cool:
...the out side will still be black :2guns:
I almost forgot to spray the swing arm. :oops:
So, I gav'er a quick wipe down
...& just hung it from the clothesline. :thumbsup:
Well, for not workin' with or using an actual spray gun for years
...then, using a new/unfamiliar spray gun (HVLP)
...with new & unfamiliar paint & materials
I think it turned out "pretty good" :cheers2:
...it kinda "flips" :rolleyes:
I'd giv'er probably a 6 out of 10. :p
* There's a learning curve to this
...don't worry, I'll do better next time. :2guns:
** If ya look closely, the clear is totally running/drippin' off of the bottom edge of the swing arm. :ack2:
I think the tip in the spray gun was too big. :idea2:
Is it blue or is it purple? :rolleyes:
...kinda depends on your point of view :lolgoku:
Here are a few more "color shifting" pics :thumbsup:
After letting the paint dry/harden for a few days
...it's time to get 'er reassembled :cheers2:
I installed the rear axle onto the swing arm first
...then started installing the swing arm onto the kart. :2guns:
I suggest that (for safety reasons) you use some good locktite on those bolts. It doesn't need to be the permanent thread-lock, it just needs to be strong enough to keep those bolts from backing out while riding.
I didn't forget. :thumbsup:
Used some for mounting the caliper too. :2guns:
Finally gonna put these Unelli tires to use (they been sittin' around here for like a year now) :thumbsup:
The rims have (2) different profiles on the outer edges
…(1) side seems to curves in a bit
So, I bolted a rim down to the work bench (with the "curved in" side upwards)
...kinda like a third hand to help hold it in place
I lubricated the inside (bead) of the tire & rim with some dishsoap
…& was able to just "muscle" the first side on.
The second side wasn't as easy
...just had to use a little ingenuity, lubricant & some tools. :cheers2:
Then, I had to pressurize 'em & deflate 'em a few times to get the bead to slide a bit & seat.
They looks pretty good. :2guns:
I knew they were small
...but, WOW!
I must say "these are some really small tires" :huh:
The rear wheels off of the Torsk kart are 13 x 6.50 - 6 (~13" tall)
…& the fronts are 13 x 5.00 - 6 (~12" tall)
These Unelli's are 10.5 x 4.50 - 6
…but, only ~10 1/2" tall :huh:
Once I got the wheels mounted (don't forget the keys) :lolgoku:
*the left rear wheel needed to be off until I got the brake cable installed
I started installing the electronics. :thumbsup:
I have it set up as pretty much a "modular" system so, I just bolted the control box down
...then, mounted the motor
...then, the dash
...& then, finally the steering wheel/hand controls. :cheers2:
Ran, attached & adjusted the brake cable
...then, used a couple of zip ties to keep the wiring harness & brake cable in place.
Now that we have brakes, we need to add the brake lights. :thumbsup:
Since this kart has a 48V system, we need (4) 12V lights, wired in series.
Gettin' the brake lights wired up :thumbsup:
The white wire from light #1 is the negative (-) RTN
…& the black wire from light #4 is the positive (+) input
I connected the black wire from light #1 to the white wire on light #2
…the black wire from light #2 to the white wire on light #3
…the black wire from light #3 to the white wire from light #4
…& finally, the power/RTN wires from the harness. :cheers2:
I drilled holes in the protective boxes, for the wires to run thru
...then bolted 'em down.
Looks good-n-solid :cool:
BOOM!, we have brake lights :2guns:
JTSpeedDemon
2019 Build Off Winner!
Texas
It is certainly Functional Art.
Even though I haven't seen a fully completed photo yet, I can tell it's gonna be real purty!
