custom exhausts!
r_chez_08
Should be in the shop...
Cornwall, UK
wierd! do they usually? also how loud is your 2 stage header, and would it be hard to make one similar (but of lower quality!)
jr dragster T
Cold place
My kart with the stock GX200 with the 2 stage header has a nice kinda quiet idle but as soon as you punch it it screams.
r_chez_08
Cornwall, UK
i am now thinking of using a lynx deoderent can near the end as a silencer, but i cant weld it as it is made of aluminium. how else could i keep it in place?
here is a pic of my idea with terrible photoshopping!
i was going to use 30mm i/d tube/pipe and have it going right through the can, with a few holes drilled in the tube when it enters the can, and a few holes in the end of the can.
Kaptain Krunch
Pro Junk Collector
vermont
You can drill a few holes in the side of the can and put some springs in there, then stretch them back and attach them to the pipe, you can weld a few wasters upright on the pipe for the springs to attach to.
r_chez_08
Cornwall, UK
thanks
i dont have any springs, so i might get a bigger bit of steel tube and jam it either side of the can and weld it.
Kaptain Krunch
Pro Junk Collector
vermont
Putting the lynx can on the end with just a few holes drilled in the pipe and a few in the can wont do as much as if you put it right over the top of the pipe and drill a bunch of holes it the can. Or if you have one pipe going into the can thats blocked off at the end with a bunch of holes drilled in it, then another pipe in the other end, also blocked off with a bunch of small holes drilled in it.
Heres the inside of a car muffler, and thats kind of how you could set up the lynx can, except smaller and a little different (pipes dont have to be offset, and you dont need the separate chambers).
r_chez_08
Cornwall, UK
may work, but how would you stop the can comig towards the wire if the wire bends? what about this?
r_chez_08
Cornwall, UK
wait the bit of wire on the other side hold it! stupid me! i may try that, but wouldnt the method above be stronger and look better?
theo
I would be afraid of loosing power with these can ideas.
theo
Kaptain Krunch
Pro Junk Collector
vermont
I just went out and whipped one up, i dont see much power loss myself, i made mine pretty high flow, and it sounds nice. I doubt i'll use it though, because i need all the power i can. I have a 100c bike engine on mine and its geared for 60mph haha so every little bit counts. Anyways, yea r chez, using the bigger id pipe on each side like locking collars would work good.
theo
If you do a reading with a straight pipe then add on your muff and recheck your top speed, you will see if there is a power drop.
theo
Kaptain Krunch
Pro Junk Collector
vermont
I dont have a dyno, thats my calculated speed. I'm sure it lowered the total hp by a little, but not very noticeable.
r_chez_08
Cornwall, UK
theo
im no worried about a small power drop, as i probably wont use it all for a while.
i dont want my exhaust too loud, as i think it would **** me off. i just want to do whats best for the engine, and apparently even some of the worse custom mufflers are better than a stock exhaust.
r_chez_08
Cornwall, UK
ok, i mocked something up on the ground today. i have scrapped the deoderent can idea, as my can was flimsy and broke. here is a pic
