custom exhausts!
Drummining1monkey
whats the best type if tubing to use for exhaust thats light but will hold up that I could get from lowes or homedepot or someplace like that. I was looking at steel pipes but thought that would be too heavy and sink drain pipes may not have been able to hold up to the temperature.
EMT, also known as electrical conduit. As long as you don't mind the fact that it's galvanised. You can get it in straight lengths, and 90* bends, which you can cut down as necessary.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Heres my exhaust creations. Note the crazy looped pipe in the last picture. Its really quiet.
KieranM
Doin It!!
Kilkenny, Ireland
i can imagine how hard that would have been to weld, i have seen ones tigged for classic fords (granted different style) and i thought that it was the only way to do it, how many pieces did you use?
Just for using arc i have respect for you on something this complicated lol Never seen one arc welded before.
devino246
Lynchburg, VA
It would have turned out better if i had done a better job of cutting the pieces & had thinner rods. What was real hard was welding on that muffler. The tank i used was only 1/32" thick.:roflol:
Bluethunder3320
My exhaust on my briggs i just found a 1 foot long pipe and welded the connector of a rusted out threaded piece. Doesnt look bad, it looks natural, but it sounds like bubbles. Is it too short you think?
Routy
quick question could i connect a 4stroke ktm exhaust to a 400cc 2stroke snowmobile engine? here pic of exhaust its not this exact one but looks like it.
Bluethunder3320
Err, if you make a expansion chamber connected before it, i guess you could. One of my friends asked me this like a month ago!
A 2 stroke needs backpressure to run correctly (can run straight pipe, but wont get performance. Youd be better woth a box muffler. A 2 stroke, has both intake and exhaust open at just about the same time.
A 4 stroke has valves that open each intake/exhaust at different times meaning it will run fine with straight pipe exhausts. Never, Ever put an expansion chamber on a 4 stroke.
I hope that kind of explains it!:smartass:
redsox985
PA
While this thread is active, is there any reason that making an aluminum exhaust wouldn't work? I think it would look great buffed...or maybe sandblasted.
robbie
Osceola, Missouri
Any particular reason? 4 stroke engines used on RC airplanes use simple expansion chamber mufflers that are quite effective and do not rob any significant amount of power. Expansion chambers allow the energy in the exhaust gases to dissipate. It's a good design.
sideways
Unfinished projects king.
Perth, Western Australia
:mad2:
No. Back pressure by itself will kill performance, it will also yield a slight increase in fuel economy. Expansion cambers work by rebounding the pressure waves caused by combustion, these pressure waves push the fuel/air mixture that have "leaked" out the exhaust port back into the cylinder thus "supercharging" the engine. Now, if you combine back pressure and an expansion pipe then things will work better, to a point. The pressure waves travel better in the pressurised (denser) gasses that are in the pipe. To much back pressure will cause the engine to overheat and cause pre ignition under the piston, also the gasses wont be able to exit quick enough and it will choke your engine.
This gif shows how an expansion pipe works very well. Note, the gasses do not deflect and push the fuel/ air mixture in, it's the pressure waves that do that.
2 strokes don't need an expansion chamber to run properly. An engine that was designed to run with one will run fine without it, just at the expense of fuel economy and power.
Think of an expansion pipe as a turbo or supercharger, it isn't necessary but it will increase power and efficiency.
Thanks
Hayden
sideways
Why? An expansion chamber is beneficial to a 4 stroke too. The divergent cone causes a vacuum pulse that helps suck air/fuel mixture in during valve over lap. The convergent cone helps quiet things down, a few modern 4 stroke bikes are running expansion chamber type exhausts in an effort to keep noise levels down.
It would discolour quickly, thus loosing that look. There must be a reason why it isn't widely used though, I don't thing I've ever seen an all aluminium exhaust, it mustn't like the heat? Many mufflers are made out of it but the heat isn't as intense by the time it has reached them. Try it and see what happens!
Thanks
Hayden
redsox985
PA
I might my shop teacher is really excited about my kart so he wouldn't charge me for metal. Once I get it all set up I'll make something. Aluminum plate to be bolted on with a large hole drilled and pipe welded on. I'll have to tune up my spool gun welding. Any suggestions for size of pipe and length on a clone? How about wall thickness? I would like it to be deep and rumble at idle.
