My 2019 model Ct200u ex has 19" tires. 16mm output shaft. 10 tooth clutch, 20 tooth js in, 10tooth js out, and 50 tooth sprocket.
So I forgot the extended chain. The omb riser lifts and moves motor forward. So the chain now about 3" short will have to get one longer. I knew I needed longer just forgotten while ordering The stock exhaust won't fit even with all shrouds removed. I have header pipe. But I thought I'd check. Waiting on one more piece for intake. I'm gonna go get chain tomorrow. So I may be lucky an have it ready to go for the weekend.
Side note I picked up used Baja for $200 It has some upgrades needs oil change,chains oiled, bolt tightening. But Runs and idles good With the old gas. These little motors are tough.
