clutch problem needs diagnoses
chris
hi. i have a single person manco critter go kart. it has a 5 hp robin engine and a centrifugal clutch.
the problem: i have recently decided to sell it and now when i go to start the engine it wants to take off. i believe it is a clutch problem but i dont know. i can manually turn the drive tire and the crank shaft will not turn. granted i have never lubricated the clutch but tried to today. the tire seems to move more freely but the same problem persists when i start the engine. can anyone help?
Kaptain Krunch
Pro Junk Collector
vermont
Most clutches dont have bearings, only expensive ones. So most likely your bushing is worn but it may just be a high idle problem.
jr dragster T
Cold place
Sounds like a broken clutch spring to me. He said he can easily rotate the tire without the crank turning. Meaning the bushing still rotates good on the clutch.
chris
thanks. i was able to take the clutch off and cleaned it up. it works perfectly, nothing wrong with it. except the problem perists. i have a strong feeling its idling too high and i am going to try to play with the throttle tomorrow.
