tribelwarrior
- Messages
- 24
- Reaction score
- 0
I loosened it just now and tried it for a few seconds but the wheels still spin.
This will sound like a dumb question but it has to be asked... When the wheels are starting to spin even though the idle is turned way down, are the wheels on the ground? You cannot use the wheels in the air as an indicator of engagement speed, they'll always want to spin. The slight load of the wheels being on the ground will tell the true tale.
So I know I need to gear down, I used the calculator on hilliards website and it says for me to even use their centrifugal clutch I would have to lower my tire size to 10", raise my sprocket size to 72t and lower my clutch size to 8t. By the time I did all that I might as well go buy a torque converter and forget the trouble with the clutch. I can get one for my kart for about 100 dollars. So what's your opinion? Change the tires, clutch and sprocket or buy a torque converter which is less maintenance and will last longer?
Also If I were to get a torque converter, could I mount the driven right on the axle or do I have to used a jackshaft? Probably a dumb question...
Every professional go kart website I looked at says I need a torque converter if I have larger than 15" tires. I love my tires so I think I'll just get a TC.
