Clutch pre-engaging...
klicky96
Sandusky, Ohio
Nope, not if you get the backplate and jackshaft. If you get the backplate and jackshaft, it will bolt right up to the engine itself, not the frame.
tribelwarrior
I thought I would post a quick update about my kart. I replaced the carb and that fixed the problem with it wanting to take off in idle. The problem was the other carb was dirty and would let enough gas in to keep it running on a lower idle setting. I also went and ordered a bullet lines torque converter from ebay. It's arriving today so I'll post again when I get it on and try it out.
tribelwarrior
It took about 4 hours to put the torque converter on and it was a very tight fit but now it can go get up to 35mph in a couple seconds. It can also haul over 500 lbs, off-road at 20mph. Also put a half quart of mobile 1 full synthetic extended performance 10w 30 in it.
