Clutch pre-engaging...
tribelwarrior
It starts fine on 1 pull and the wheels don't move when I pull it but once its on for a second or 2 it wants to take off.
klicky96
Sandusky, Ohio
I'd really try anotherr clutch. before it started smoking the first time, were you trying to take off or were you just letting it run?
tribelwarrior
I would go buy a new clutch in a heartbeat if I knew it would fix the problem but I don't wanna waste the money if that isn't the problem.
klicky96
Sandusky, Ohio
what you do is, buy the new one, then take the old one back to the store in the new ones packaging and say it wasn't the right sized shaft. :p
jman231994
Australia
Try checking your carb linkages? Throttle cable could be too short maybe? That would hold it off the idle stop screw and make it try to take off. AND DEFINITELY REGEAR. I'm going to use 13" wheels with close to a 7:1 ratio, I honestly would like a lower gear ratio to have more fun :p Maybe go 8 or 9:1 ratio even. I may have just missed it but it would be wonderful if you could get some close up photos of the carburettor linkages, throttle cable, and carb in engine setup in general. It will be heaps easier to help you if we can see whats going on.
You say that the engine is on its lowest possible idle before it dies. If this is the case, then the only possible thing that can be the problem is your CLUTCH. There is no arguing about it. If the chain is not tight, if the blots aren't restricting the clutch in any way etc, then it is still your CLUTCH that is the problem.
There is nothing else on the kart that can cause this problem. Gearing will not cause your clutch to engage at idle, only RPM's.
Whether you fried the clutch before or after it engaged does not really matter. If everything is OK on your kart....then it is your CLUTCH that is the problem.
Whichever way you look at it, if you have tried everything we have suggested....it is your CLUTCH that is the problem
So what I suggest is that you buy yourself another clutch, pop it on your kart, and see what happens. You will probably find that it will not engage. Sometimes clutches can be defective, it happens
Just to repeat myself....if you have tried everything suggested by us, then it is you clutch that is faulty. Are you 100% sure that your engine is actually idling as low as it can. You might think it is, but your carb could be dirty and not allowing it to idle properly. No matter how you play with the idle screw you might potentially not get it to idle low enough.
I suggest you post a vid of your engine idling. That will tell us right away if something is wrong
This will sound like a dumb question but it has to be asked... When the wheels are starting to spin even though the idle is turned way down, are the wheels on the ground? You cannot use the wheels in the air as an indicator of engagement speed, they'll always want to spin. The slight load of the wheels being on the ground will tell the true tale.
klicky96
Sandusky, Ohio
This is why I saisd to lock them in place, lol. If he can lock them in place, and start it up, it should be fine.
tribelwarrior
So I know I need to gear down, I used the calculator on hilliards website and it says for me to even use their centrifugal clutch I would have to lower my tire size to 10", raise my sprocket size to 72t and lower my clutch size to 8t. By the time I did all that I might as well go buy a torque converter and forget the trouble with the clutch. I can get one for my kart for about 100 dollars. So what's your opinion? Change the tires, clutch and sprocket or buy a torque converter which is less maintenance and will last longer?
tribelwarrior
Also If I were to get a torque converter, could I mount the driven right on the axle or do I have to used a jackshaft? Probably a dumb question...
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
You need to do ONE of those, not all of them. I suggest changing the axle sprocket.
tribelwarrior
Every professional go kart website I looked at says I need a torque converter if I have larger than 15" tires. I love my tires so I think I'll just get a TC.
No, the driven unit never gets mounted to the axle. Doing so would not allow a low enough gear ratio. You will need a jackshaft, of sorts. If you get a TAV2 style self-contained unit, the whoile thing bolts to your engine and contains it's own jackshaft. You simply have to run a chain to your rear sprocket. Most other units are entirely separate driver and driven units. If you elect to use one of these, you will need to fabricate or purchase a separate jackshaft. On that shaft, you will mount the driven unit, and an output sprocket of your choosing. From there, you run chain to your axle.
klicky96
Sandusky, Ohio
Professionals just want you to spend more freaking money. This is entirely wrong. If you really wanted to know true facts, there are three things you can do. 1) Put a 72T sprocket on your axle (I guarantee this will work, it won't give you much take off, but it will give you enough to play around), 2) Use a torque converter, or 3) Use a jackshaft. Don't believe everything you read. Talk to people who have had experience with this kind of thing. Thats what we are all here for. We have had our own experiences and we all learn from eachother.
