Staff Murderator
- Messages
- 9,447
- Reaction score
- 4,376
It is Dinky but for Most Garage Kart mechanics that 3oz tube is more than enough.
I also have a standard size grease gun, whatever that is! lol
Here's your sign, dude:
Hellion, 100% gas! Something to invest in i guess. Looking it up i cant find a station where i live.
http://www.pure-gas.org/
Looks like there is one for the OP in Phoenix! Hmm closet one to me is in Anaheim. Bringing a gas can next time i go to Disneyland!
Does it really make any bit of difference on a small engine if you run high octane or not? Will you get any performance gain by spending more on gas?
You do not need pure gas and you do not need high test gas.
These engines are designed for yeoman's duty. Putting in more expensive fuel than you need is just for your head, it is not for the motor, because a stock motor is not capable of the high compression and ignition advance that makes premium fuel necessary in high-performance engines.
There will not be a performance gain if you run high test. The motor will be harder to start. Why? Because high test gas is harder to ignite. That's why a high compression motor needs it - to prevent detonation.
---------- Post added at 03:06 PM ---------- Previous post was at 03:03 PM ----------
Oh, and OP, there is no VIN on a go-kart.
You contradicted yourself in your last paragraph.
I do not believe that I did.
Theres that little metal thing on the side (not the one for the air) and i dont know what its used for, can someone explain? And for the bearings i should be putting high speed grease correct? can someone direct me to a good/cheap high speed grease.
A grease fitting, grease nipple, Zerk fitting, or Alemite fitting is a metal fitting used in mechanical systems to feed lubricants, usually lubricating grease, into a bearing under moderate to high pressure using a grease gun.
Here's your sign, dude:![]()
What I was saying was, dear Chancer, was that you basically added nothing to the conversation because while advocating the mini-greaser you destroyed your argument by saying you had the "man-size" one as well. And since when is "more than enough" ever the right answer (because you can never have too much)?
I guess you've never been a product spokesman before?![]()
When the 'Pox-eclipse' rolls around, you better have the man-size greaser because those grease cartridges will be more common... and foraging in the wasteland is no fun.
Whatever dude! If a guy does not have a grease gun and may need one for the only 2 zerk fittings on his Kart. and the only two he has ever seen in his life Then the 9.99 HF one is a good deal.
You mentioned you had a "standard size" one. I agreed that it is small, and agreed with you that I happen to have a "standard size" one as well. I would not tell a guy he needs to rush out and get a 39.99 Snap on tools standard size Grease Gun and some Kendall super blue for 27.99 a tube.
K.I.S.S. Right?
BTW I plan on being Raptured before the Apocalypse!
Until then Too much AMMO is never enough. but grease? meh!
Whatever dude! If a guy does not have a grease gun and may need one for the only 2 zerk fittings on his Kart. and the only two he has ever seen in his life Then the 9.99 HF one is a good deal....
