choke on go kart shuts engine.
Staff Murderator
It is Dinky but for Most Garage Kart mechanics that 3oz tube is more than enough.
I also have a standard size grease gun, whatever that is! lol
Here's your sign, dude:
Iron John
NA
Hellion, 100% gas! Something to invest in i guess. Looking it up i cant find a station where i live.
http://www.pure-gas.org/
Looks like there is one for the OP in Phoenix! Hmm closet one to me is in Anaheim. Bringing a gas can next time i go to Disneyland!
Does it really make any bit of difference on a small engine if you run high octane or not? Will you get any performance gain by spending more on gas?
You do not need pure gas and you do not need high test gas.
These engines are designed for yeoman's duty. Putting in more expensive fuel than you need is just for your head, it is not for the motor, because a stock motor is not capable of the high compression and ignition advance that makes premium fuel necessary in high-performance engines.
There will not be a performance gain if you run high test. The motor will be harder to start. Why? Because high test gas is harder to ignite. That's why a high compression motor needs it - to prevent detonation.
---------- Post added at 03:06 PM ---------- Previous post was at 03:03 PM ----------
Oh, and OP, there is no VIN on a go-kart.
Staff Murderator
You contradicted yourself in your last paragraph. A high compression performance engine will benefit greatly from the anti-knock properties of high octane guzzoline and will run a lot better. Detonation, as fantastical as it may sound to the amateur, is not conducive to generating power.
Just because one of these engines started out as a "yeoman's machine" doesn't mean it cannot be upgraded for insane, unheard of performance. That's what most of us are doing here anyway in one form or another. A Briggs 5 HP flathead upgraded to Raptor configuration, is one example for instance. I feel silly here stating the obvious...
I will be happily using pure gasoline in all my small engines and avoiding at the same time the corrosion that fouls my tanks and the gumming-up of my carburetor innards that ethanol gas (gasohol?) has been well-documented to do.
That's a cute story. Not necessarily true for SEVERAL reasons. #1: Ethanol draws moisture out of the atmosphere...not a good thing for small engines sitting idle....hence...pure gasoline IS beneficial.
Now....higher octane....I wouldn't say the few percentage points make the engine any harder to start. Really, a proper A/F mix, good compression, and a good hot spark should light if off just as easily as a lower grade.
Better performance? Well ask yourself this: instead of focusing on "harder to ignite "....look at this: slower burning! So the same fuel charge will burn longer, creating more pressure, pushing longer on the piston...creating more power.
Still want to stick with pure or high octane as usless? If so....how about some back up proof....(In the real world...not in NA.)
cobiispo
Alright guys stop fighting about fuel on my thread lol. I was joking about having a VIn number on the go kart hahah.
But anyways, i posted more pics of m steering wheel and so can someone tell me whT i can fo about the spacing between them. Also i was gonna remove my engine from the kart bt he clutch wont come off! It doesnt have set screws but a regular bolt with a washer. Ive searched online and people are saying i shiuld put something on the flywheel to stop the clutxh from spinning? Is there a better, safer way to remove the clutch? I posted pictures of the clutch too. Oh yeah i was unscrewing the brake system and this tiny metal cylinder thing came out of nowhere( i took a pic of it too) can someone tell me what its for or if its even part of the go kart.
Ps sorry for not putting the pics directly here because im on my phone and its not working properly
---------- Post added at 03:34 PM ---------- Previous post was at 03:30 PM ----------
And also, behind the clutch on the bottom theres an open hole. Should there be a screw in there? I feel like dirt can get inside the engine.ive been reading about the governor removal thing so was that the screw for the governor? Foes that mean my governor is gone?
Staff Murderator
Why would you want to remove the engine? "If it ain't broke, don't fix it".
For the clutch, remove the bolt and the washer. :rolleyes: If they're stuck, use penetrating fluid and brute force. If the flywheel moves with the wrench on your clutch bolt, use something braced on the flywheel to lock it in place. This is an accepted method and they even sell tools that lock between the flywheel fins.
You need to get on a laptop or stop using that photo hosting site and keep the photos on your phone to upload here. To heck with that mess. Time for you to do some work instead of us.
Theres that little metal thing on the side (not the one for the air) and i dont know what its used for, can someone explain? And for the bearings i should be putting high speed grease correct? can someone direct me to a good/cheap high speed grease.
A grease fitting, grease nipple, Zerk fitting, or Alemite fitting is a metal fitting used in mechanical systems to feed lubricants, usually lubricating grease, into a bearing under moderate to high pressure using a grease gun.
Actually he asked about grease, and Zerk fittings! Bob gave him the GAB and I posted a link to a cheap grease gun.
So lets see how well you argue Octane ratings with "YOUR SIGN" stuffed keenly up your Posterior Orafice!
:backtotopic:
Staff Murderator
What I was saying was, dear Chancer, was that you basically added nothing to the conversation because while advocating the mini-greaser you destroyed your argument by saying you had the "man-size" one as well. And since when is "more than enough" ever the right answer (because you can never have too much)?
I guess you've never been a product spokesman before?
When the 'Pox-eclipse' rolls around, you better have the man-size greaser because those grease cartridges will be more common... and foraging in the wasteland is no fun.
Iron John
NA
I guess the point is that too much is not enough.
Whatever dude! If a guy does not have a grease gun and may need one for the only 2 zerk fittings on his Kart. and the only two he has ever seen in his life Then the 9.99 HF one is a good deal.
You mentioned you had a "standard size" one. I agreed that it is small, and agreed with you that I happen to have a "standard size" one as well. I would not tell a guy he needs to rush out and get a 39.99 Snap on tools standard size Grease Gun and some Kendall super blue for 27.99 a tube.
K.I.S.S. Right?
BTW I plan on being Raptured before the Apocalypse!
Until then Too much AMMO is never enough. but grease? meh!
Iron John
NA
K.I.S.S. Right?
Oh, I agree with you, that was sarcasm. :)
Staff Murderator
Whatever dude! If a guy does not have a grease gun and may need one for the only 2 zerk fittings on his Kart. and the only two he has ever seen in his life Then the 9.99 HF one is a good deal....
Blah, blah, blah. At the time I started berating you, the conversation about grease gun sizes and which is better shifted almost entirely to you. :p
I have no beef with octane ratings. I just like 100% gasoline.
Y'all have a nice day. :)
