Carter 2606-KX Clutch and rear axle
tennhi
Well..
Thrown the chain off atleast every two days... already broke the clutch belt.. about 20 bolts have backed out in various places... chain tensioner has broke... left rear wheel degenerated ...
Well..
1. Thrown the chain off atleast every two days
It happens. Check the alignment of the two sprockets and the chain tension and adjust if needed
2. Already broke the clutch belt.
Use genuine Comet belts for best performance
3. About 20 bolts have backed out in various places
Happens often on anything with an engine. Clean the threads, apply blue Loctite threadlocker to the bolts and reassemble
4. Chain tensioner has broke
Probably a wear-out item and to be expected. Buy a new one
5. Left rear wheel degenerated
Now that is utterly fantastic! Tore the center core right out of it--now that's some drivin'!
And that's garbage metal.
tennhi
Well it's supposed to be new.. the chain tension shouldn't have broken in a month... neither should the clutch belt... the chain is aligned... and a small kid has been the only one who has drove it
Time to look for another Carter Brothers kart…. *with a live axle* 😉
I wish I could give a thousand more likes to this comment.
Ive developed quite the liking to the CarterBros company. -Or rather, what it once was.
I’d want one of these. Seems like the perfect go kart of the type that had fiberglass bodies. An ATV, go kart and truck replica all in one. There’s a Grave Digger model too…
