Carb troubles
Bigjawn
I’m having extreme difficulty finding a carburetor (manual throttle) that will fit a Honda GX620 engine. The only carbs I can find for it are electronic throttle. Does anyone know where I could find an adapter or carb (manual throttle) that will fit my machine?
Bigjawn
Oof. I have a 620 and parts are hard to find. Im 99% given up on it.
Id try to find an intake manifold with that bolt spacing and cut and rotate and weld it back to the angle i need.
Ah yeah, I’ll probably wind up doing something like that
Bigjawn
Found a solution! Im going to cut and weld a carb adapter with a template from the carb intake then weld a tube on Then I’ll do the same for the other side to fit a pz26 carburetor.
Bigjawn
I have given up on this engine for the time being. Bought a new go-kart with a small homelite 179cc and will be building the previous gokart project with a Briggs and Stratton 8hp industrial plus engine. Sorry to anyone invested in the v twin but it’s going to be a lot of work and time that I don’t really have
