Can anyone help, Or heard of SONIK ?
damobear
damobear
Errrrrrrrrr u lost me mate lol
am i being dumb yea ?
irll have a lil look on line as i really aint got a clue
i am prob a thicko but dont know jack about motors or buggies
freakboy
the names 'mater
hick town
naaa you just need to make a small arm with a pivot on the bottom mount it on the controll arm somewhere and the top of the arm has a small plastic pully that spins freely and in the middle have a spring goin down to the bottom of the control arm to pull down on the chain and just put the pully ontop of the chain.
Kaptain Krunch
Pro Junk Collector
vermont
just make a metal bracket with a small plastic pully on there wider then the chain that presses down on the chain its simple but effective mabey just have a arm and a spring to keep it down
The tensioner would have to push up from the bottom to be effective. But seriously, there has to be a way to adjust the chain, even the cheapest chinese machines have chain adjustments.
damobear
damobear
really hasnt, ive looked ever where on line 4 service manual for the thing, its driving me mad feel like crying ha ha
sonik, crazy king 2
yh250a (eec)
arrrrrrrrrrr gonna go to china and blow the bloody sonik place up i think
they havent replied to my mountains of mails either
toofarnorth
Wasilla, Alaska
I agree with Kaptain Krunch it's doubtful they would make it with no way of adjusting chain tension. I still say you should take apart the rear axle assembly and look for the adjustment inside, the worst that could happen is you have to put it back together and you learn a little more about your buggy, but you may be able to fix it without having to cobble an idler on to it.
anderkart
Surprise Arizona USA
I agree, either the engine has to have some means to adjust forward or back, or its missing its factory instaled tension-er pulley, or that whole drive wheel assembly must somehow have the ability to adjust/slide forward or back on the swing arm to adjust the chain.
Looking at these pics:
http://www.diygokarts.com/vb/attachment.php?attachmentid=4427&d=1248894706
http://www.diygokarts.com/vb/attachment.php?attachmentid=4429&d=1248894706
I cant be sure from the picture angles, but that swing arm seems to have an oval shaped adjustment slot with a bracket bolted to it, located just in front of the sprocket. I was thinking If this bolt was loosened, (and possibly all the other related bolts) it might allow the whole rear wheel assembly to simply slide forward or back to adjust the chain simalar to like a motorcycle does.
damobear
damobear
Thats what i thought to start with but it doesnt, it looks as if it should slide back n forth but its fixed, well looks like its welded from the other side, but made that way if you get what i mean, ive spoke to the guys again in my local bike shop and they have ordered me a roller tensioner or sumin, they think this will help, but everybody agrees its madness that it has no other means of tensioning the chain, it just doesnt make sense, also ive had loads of people looking for info on line about this buggy and no one has had any joy, know where it is made etc but nuthin in the way of help in any shape or orm, lol it seams i bought a buggy that no one knows much about lol just my luck :(
toofarnorth
Wasilla, Alaska
So what happens when you pull those bolts out of the rear of the axle housing? Don't forget to jack it up to take the weight off the axle.
damobear
damobear
got a roller tensioner today but its made of a hard plastic material, and can see anyway of fitting it really but think it would get eaten by the chain even if fitted it to be honest, But where i was moaning in the pub some gezzer heard me and he is coming to have a look tomorrow so fingers crossed :) irll let you know how we get on, he is a motor bike mechanic by trade but has been working on cars for the past few years so hopefully he may get it sorted :)
damobear
damobear
ARRRRRRRRRRRRRRR the kiddy couldnt help he was a doughnut :p
been given a roller also that is ment to extend the chain when to lose i.e. if i put the extra link in so its too slack, but its plastic and i have no way to attach it anyway, when i undo them bolts that look like they slide back and forth, all it does is losen the caliper as that is all its attached to :( so total stuck again, but gonna give it a go in a sec was just letting you guys know the sitution at present
toofarnorth
Wasilla, Alaska
Just send it to me if I can't fix it I'll eat my hat :thumbsup: or take it to a car mechanic and tell them I said any competent mechanic could fix it, that way if they can't they have to admit that they are incompetent.
damobear
damobear
lol ive had about 3 mec look at it and 2 bike mec and a bloody buggy mec, its a joke i swear, cant belive a chain could be so much grief, the buggy kiddy told me to drive it with just the one chain ? bloody mupet lmao
toofarnorth
Wasilla, Alaska
Well if you won't send it to me at least do me a favor, jack it up take off the tire and take lots of pics with at least one of them straight at the hub with the axle housing in the background. Was the hole that the caliper was bolted to slotted? If it is I think I know how to adjust it. loosen that caliper bolt and loosen those six (i can only see five but it looks there should be six) hex headed bolts at the back, then you should be able to rotate the hub (the part sticking out both sides of the housing looks greenish gold in the pics) in the housing (the part the six bolts are in) and I bet axle isn't centered in the the hub so when you rotate the hub it will move the axle forward and back.
damobear
damobear
okey dokey irll do that now, not sure if this is what you mean but it doesnt look centered (the whole back end i mean) the other side seams to be further forward, and i even took the chain off the other side and tryed fitting it to the prob side and had excatley the same grief its to short :(
damobear
damobear
pics
is this any good ??
damobear
damobear
pics
here u go pls help
damobear
damobear
pics
help lol
