Hi @Mr_mcrib212
Re: Post 215 photos 2 and 4...
Did you put in a couple of extra washers between the 2x4 front end and the 2x6 frame to minimize interference when attempting to turn ?
An upgrade would be a 3-1/2" diameter disk from a cheapie plastic cutting board (at least 3/8" thick) then put the correct size hole in it to make it into a really big washer that may spread out the load from the steering to the frame.
Also sure to put on a nylock nut or drill and wire tie to keep the nut from loostening on your steering.
I still think about a plywood kart ever once in a while. Ever see LVL beams ? They are load rated and can be scaled wider thn thicker to be load bearing beams in houses !
---------- Post added at 06:52 PM ---------- Previous post was at 06:39 PM ----------
BTW, sure you have seen something similar on YT, like BuildBreakRepeat's wooden kart tribute build.
This one by a school team uses plywood and electric motors and would pribably shatter the 15mph safety barrier IMHO. It could handle a good gasoline engine upgrade.
https://youtu.be/XCvnm4QMhN8
