Got the engine back on, gas tank and fuel lines sorted.  All that's left is wiring a kill switch, and she's done.
The gas tank is (was) a 2 gallon tank off a broken harbor freight twin-stack compressor.  Cut, cleaned the inside, shortened, welded, added a neck, and made a cap (till my brass one comes in).
I'm planning to put a regular GX200 or clone carb on in place of the dual-fuel clone carb thats still on there from my propane testing.  The larger throat Honda style carb really wakes this engine up compared to the stock one.
I did take it out and tear it up today... Even with the 4.8:1 gear ratio and 15" tires, it does well climbing hills, and has a pretty respectable takeoff.  I may bump the jackshaft sprocket down to 9t for a little added oomph.  If the race ever happens, I definitely won't need a 43mph top speed, due to the terrain, but a little extra torque would be beneficial.
Oh, and the air filter is just a regular tecumesh OHV style filter with a quart paint can lid as a backer plate cut to match the carb inlet.  A little bit of plumbers strap and a 1/4"-20 bolt make the hold-down bracket, with a plastic wing-nut from idk what.
The entire build came in around the $200 mark, though I lost exact count a while back.  If I had to purchase the engine, axle, and wheels, it would be closer to 400, but still within the specified budget.  Not that that really matters anymore
