I got to about 6200 rpms with my stock uncorked predator with 18 lb springs with the stock carb and a cent clutch. Could be the tav/ gearing keeping your rpms down. The big tire baja heat type bikes are gear pretty high with out the jackshaft. Bigger carb will give you more rpms but you may loose low end.
