Briggs 5 hp performance upgrades
Well, I have been busy emptying my pockets, and have finally gotten the engine started. I was debating putting in a raptor III piston, and I am glad I did so the engine will be reliable at 7000 rpm. I doubt I will hit that as the carb is the most restrictive point on the engine now. The porting I did, was just to knock down the casting flaws so that can be improved on, as well as decking the block, but I will not do that at this point.
One pull on choke and it died, second pull with choke off and it fired right up. Yay! Good ol honda carbs (or knockoff in my case).
For those of you that know briggs. I used a newer cup style recoil on the old school crank... This means that I actually cut the crank off at the thread for the nut. I dont reccomend doing this, but there was no way I was ever going to use the old school pull start. I remember messing with them as a kid, traumatized for life. I had to space out the flywheel cover by 3/8" as the original block had a different side cover.
For break in, I set the RPMs to 2500 from idle and ocasionally varied from 1600-2500, mostly keeping at 2500 with a light load (torque converter on it with belt, no chain). Turned it off after 10 mins of run-time and will repeat this 2x, then will empty break in oil, inspect, add the other half of the quart bottle of break in, then lightly ride around for a while.... next week... when I don't have work *sigh*
Here is what's in it:
.027" copper headgasket (stock is .050")
94SS cam (mild cheater cam)
billet stock length lifters
new/aftermarket 'stens' valves,lapped, and lash set to .005" intake and .006" exhaust
springs recommended by checkered flag racing for the cam and other parts
honda clone carb, with custom made intake/exhaust/throttle
header is .87" ID (25mm OD sanitary stainless)
muffler (yet to be put on) RLV 1" ID
hardened retainers
arc billet connecting rod, stock length, clearance within spec
arc billet flywheel, non adjustable, lapped, timing set to 30 deg btdc (cam recommends 30-32) magneto gap set to .030"
spark plug indexed (open side faces exhaust), gapped at .030"
Raptor III standard size piston and rings, with raptor wrist pin
