Best welds thread :D
95badbird
Srping TX
Thanks, means a lot!
I am running a 351 Windsor, C4 settup, out back is factory IRS with 4.10's.
I want to back halve the car, and get rid of the IRS.
Here is an old shot of the engine and bay.
AMMFAB
Phoenix, AZ
right on..... i know sport compact cars and newer mod powered mustangs and lsx powered f bodys and vettes, but not a whole lot outside that circle. i didnt thing those would have irs setups...... did they come with the windsor stock..... i know there were supercharged and turbo t-birds but dont know about the v8's.
mike
95badbird
Srping TX
mike
mine came factory with the 4.6L mod motor from ford. It did not come factory this way, nor did the C4.
It is strictly a race car for the most part......hence why i would love to get my heads done by a profesional....wink wink.
95badbird
Srping TX
i was afraid you would say that......they are cast.
but thats okay, I want to toy with them a little, i had already boguht some 6 inch bits and a cartridge roll set to clean them up, and do a little intake to head matching.
I will keep you in mind when i buy a set of AFR 225's.
Bluethunder3320
heres a root pass 7018 vertical up(3F), 90 amps. welded with a miller. little bit of undercut but not too bad. havent done much of this yet. the steel is snow plow blade off state trucks
machinist@large
West Michigan, 49331
:cheers2::thumbsup: You're getting close, Blue!!! You'll KNOW you're there when you finish running one end of the bead and the slag is curling up off the bead at the other, and doesn't stop 'till it gets to the other end (WITHOUT using the hammer!!). It is so cool to watch.........:cheers2::popcorn:
Bluethunder3320
thanks man!
AMMFAB
Phoenix, AZ
heres some of mine as of recently....
16 gauge stainless
inside after backpurging....
304 stainless sch 40 pipe.....
aluminum....
cavalier down pipe...
dsm down pipe....
mike
I don't ever expect perfect welds from my 130A gasless MIG but, these welds surprised me
souperman000
Westlake Village, CA
I just started to weld in December. I get to weld a little bit every few weeks so I don't have a ton of experience but I have been getting better.
These are my two best welds so far. I was putting an angle iron leg in the corner of a rectangular base also made out of angle.
Rustydog2010
NZ Nutta :|
New Zealand
Keep going mate, practice makes perfect.
Looks like you where going a bit quick in the first picture. Slow it down and /\/\/\/ instead of going ------. If that made any sense? :lolgoku:
Second picture looks good on the right of it anyway. :thumbsup:
How does one get such a large gap between the overlap?
From the second pic, it looks like you could do with a bit more heat, it doesn't appear to have "bitten" the metal too well; the line between the weld & the base metal should be "blurred".
Having said that, as rusty said, you're doing ok for a beginner, keep practicing...
A little tip: To test the strength of a weld, break it (by whatever means necessary), the metal should break beyond the weld
souperman000
I just make litttle U's back and forth. The left side of the second picture I think I was just trying to fill a gap or something...;)
Im not sure how to adjust the heat on the welder. Its not mine so I just turn it on, set the gas and start welding.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
I don't do a whole lot of welding anymore, but I did this a few weeks ago. SMAW, 6011 rod, 1/8" angle iron.
