Baja Warrior Mini Bike
Bluethunder3320
yeah if you have a spare motor i say go for it.. lol....
i like tearing apart and modding engines. i got this h60 that i keep modding and rebuilding endlessly.... its bulletproof.
B.M.800
TheBeal.
Central PA
Aright, goin fer it!
:devil2:
No turning back... broke part of the spring...
{EDIT} hahaha! I dont Idle no more! As soon as it starts its engaging the clutch... oops?
Alright.
Fiddlement 1, no idling.
Fiddlement 2, back to normal
Fiddlement 3, Yes, defiantly got faster... Dont know how much, but it is. Its great.
:bannana:
Thanks Blue!
kendelrk
redneck engineer
westland michigan
no, what you should do it set it back as it was, take some heavy wire like 10 gauge, run it into the arm hold and put it into a place on the arm, itll bypass it and youll get a lot more out of it
Bluethunder3320
i wouldnt completely bypass the gov. if you do this you should just remove it completely.
B.M.800
TheBeal.
Central PA
Whats done is done, maybe Ill go back a fiddle with it some other time, but for now I am happy. :2guns:
Bluethunder3320
went riding alot today. found a field. heres 2 pics. only 1 coke totally survived the trip.
brakes are toast.
Bluethunder3320
just ordered honda brake pads. thanks to kendel for getting me the info on compatibility!
i should get them in a week. ran me $29.
Bluethunder3320
those brakes are toast! did something die in there or what? LOL
well whoever had it for the 5 years before me, must have really beat the crap out of it and drove through water and mud!
:roflol:
one pad was shattered. other was paper thin.....
took all the shattered pieces out and i didnt have brakes at all. noting.
r97
Measure twice cut once
Massachusetts, USA
i still think you should make that a real tank! :D, even though its fake it looks 10X better with the tank!
Bluethunder3320
yeah i can agree with that! well im off to do electrolysis on the chain, and weld a patch on the gas tank..
the tank leaks gas out the fuel meter area so im just gonna weld a piece of metal over it.. dont use the meter anyways its not accurate.
Bluethunder3320
I hope you fill it full of water first, otherwise this may be the last post we here from you.
:roflol::roflol::roflol::roflol:
i almost died when i read this! im not that dumb, i know not to weld on a gas tank that has gas in it :roflol:
okay so i need a new gas tank now.
heres the order of events.
drained gas.
removed the tank, and oops, wrecked this spring. well i have a spare so its ok.
took some paint off.
marked a piece to be cut out of some thick steel...
cut the piece out, perfect, tight fit.
things started to go wrong once i started welding. i realized, this tank is made out of super thin, tin foil like metal. it did nothing but blow holes and i spent hours grinding and welding to correct them.
the affected area grows, it leaks so much.
and heres what it was doing. so frustrating. just makes holes, i was welding on speed 1-2, minimum amps. also i was stopping and starting so much to try to keep it from melting to nothing.
so thats my story, i need a new tank. its hopeless. i dont have the tools to fix this. :worried2:
fowler
Bullsbrook West Aus
i disagree
if u were doing this on a car u would have filled the tank with deisel and welded it up
we have brazed truck tanks up with deisel running everywhere
it that a real lid on the fake gas tank?
could u just add a petcok to the tank and use it?
if not surely u can weld a lid on
i agree with r 97
Bluethunder3320
the fake tank is just a shell. the cap isnt unscrew-able. it would take alot of work.
cant find a tank for less than $40 plus shipping...
