r97
Measure twice cut once
That looks like an awesome place to ride!!!!!
How long till you get your JOL? I think maybe you should just happen to bring the chainsaw with you next time you go.... trails are now open!![]()
So... how does that sound?
Losing compression. Get a pair of dirt cheap piston rings and find someone to hone the bore and you are set.i rode it back with no problems. should i be worried?
should i be worried
Uh, considering you just had the valves out and were goofing with the spring rates, I'd check to make sure you didn't just suffer from a stuck valve and piston/valve collision resulting in a bent valve.
I would go to HF and buy a new motor, they are on sale for $99 until the end of the month![]()
BAD news. my motor (i think) is blown.
i was down in the tobacco fields with my friend andrew, scott, justin, and rob, and i rode justins KTM 200 while scott rode my warrior. when i met up with him again, he was on the side of the trail unable to pull start the engine. SIESED!
i unscrewed the oil (changed it this morning) and let some pour out. it smells really gassy and its thin. so i put the plug back in and tried to force over the engine. it slowly loosened up and then felt like it had no compression. i finally got it to start and it blew out TONS OF BLUE SMOKE. the smoke went away after a while, and the engine was slowly more powerful.
sweet video in a few!
