Easiest?
Switch from 10T to 8T
60 : 10 = 6
60 : 8 = 7.5
((7.5 - 6) / 6) * 100 = 25% Increase in torque.
I think I had to grind the sprocket to make it fit, does that count as machining?
You can switch the spring setting on the TC driven unit. I don't think this will help you much.
Three settings
One is for staying in low gear longer.
One is the middle one.
One is for upshifting faster.
You can switch to a stiffer driven unit spring to stay in low gear longer, but again I don't think this will help much.
---------- Post added at 12:48 PM ---------- Previous post was at 12:46 PM ----------
Besides that smaller tires.
Thinner Head Gasket to increase compression.
9.5:1 with 87 octane.
Need to measure with the head off and use an online calculator.
Keep 0.030" Between the piston top and the head.
So if your piston is 0.020" in the hole, you can use a 0.010" gasket (if with in your octane range).
If your piston sits flush, you can use 0.027" - 0.032" gasket (if within your octane range).
Depending on Piston to valve clearance, they make ratio rocker arms to give your cam more lift (and also duration a bit - I think). More lift = more power at all RPMs.
Keep 0.060" (minimum - "ish") between the valves and the piston.
---------- Post added at 01:09 PM ---------- Previous post was at 12:48 PM ----------
The Sprocket
http://www.bmikarts.com/41-Sprocket-with-58-Bore-B-Type_p_1050.html
This gasket might fit? Says for gx200
http://www.nrracing.com/product-p/12251-zl0-003.htm
1.1 : 1 Ratio rockers
http://www.nrracing.com/product-p/rerockhd.htm
Turn a 0.275" lift cam into a 0.303" lift cam.
