Welding, Thermo neuclear fusion, bolts, screws, or epoxy.
Unfortunately i do not have a welderWelding, Thermo neuclear fusion, bolts, screws, or epoxy.
I can send it later today. I will send a picture of the pulley next to it as well
Oh ok. Well I hear a lot about a live axle and a sprocket with a chain, what would be a cheap like super cheap option for that?
Another thing to consider, is the size of the pulleys (that you don't want to use). Just like gears, sprockets and hydrodynamic proton drive, size matters. Random sizes probably won't work anyway.Ok. So should i try to find a sprocket and chain? or should i just keep the free option of the belt and pulley i already have (i didnt buy those i salvaged them)
Yes i have a frame. Im making a custom build of a go-shopping-kartFind a wheel that already has a sprocket attached. Do you have a kart frame to mount the wheel on?
Yes the sizes work. Belt, pulleys, and engine are all from the same snowblowerAnother thing to consider, is the size of the pulleys (that you don't want to use). Just like gears, sprockets and hydrodynamic proton drive, size matters. Random sizes probably won't work anyway.
We need pictures if you want intelligent answers. Have you ever heard the term " Garbage in, garbage out"?Yes the sizes work. Belt, pulleys, and engine are all from the same snowblower
i didnt say your response was garbage i thought you were being helpful. I just needed a couple of tips. I can send a picture at some point but not right nowWe need pictures if you want intelligent answers. Have you ever heard the term " Garbage in, garbage out"?
If you can't post pictures, please do not expect anything like a helpful answer, OK?
