Attaching a pulley to a wheel for a 1wd go kart (belt drive)
caedont
I’m wondering, can anybody tell me the best way to attach a pulley for a belt on to a small ish wheel hub? There aren’t really any flat sections to bolt into, I don’t want to risk popping the tube. Maybe it wont. Anyway somebody please help😭
caedont
Oh ok. Well I hear a lot about a live axle and a sprocket with a chain, what would be a cheap like super cheap option for that?
caedont
Also hellion heres the wheel hub, its just from the website, couldn’t get around to actually taking a pic of hte one with the pulley
caedont
Ok. So should i try to find a sprocket and chain? or should i just keep the free option of the belt and pulley i already have (i didnt buy those i salvaged them)
Another thing to consider, is the size of the pulleys (that you don't want to use). Just like gears, sprockets and hydrodynamic proton drive, size matters. Random sizes probably won't work anyway.
caedont
The basket is not where im mounting it. Im using an actual frame that is modified from the bottom part of the shopping cart. Its very hard to bend i tried
caedont
Yes the sizes work. Belt, pulleys, and engine are all from the same snowblower
caedont
We need pictures if you want intelligent answers. Have you ever heard the term " Garbage in, garbage out"?
If you can't post pictures, please do not expect anything like a helpful answer, OK?
i didnt say your response was garbage i thought you were being helpful. I just needed a couple of tips. I can send a picture at some point but not right now
