Ask poboy
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Question:
Isn't Christmas greetings considered a religous subject? How can we get away with that?
Poboy kartman
Senior Moments Member
White Settlement Texas
Question:
Santa...(aka father Christmas) ....is non-denominational.... the Easter Bunny on the other hand is......
---------- Post added at 12:57 PM ---------- Previous post was at 12:50 PM ----------
Doug, I don't mean to hurt you're feelings but, I have seen better advice from a Magic 8 ball. :rolleyes:
"Signs point to yes"
---------- Post added at 01:02 PM ---------- Previous post was at 12:57 PM ----------
That's a good question, what exactly is that crap in a magic 8 ball?
IDK, but I've found it makes a poor substitute for Coca-Cola as a bourbon mixer.
On the upside....if you accidentally swallow the little white die....you can see your future in the toilet later on...:thumbsup:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Question:
Nope, Sorry but Santa Claus, Christmas trees, Presents, and Miseltoe have absolutely NOTHING to do with any of the 5 major world religions.
So Merry Christmas Nick!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Well too bad you did not completely fill in your Profile. I could have sent a card!
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
How long is a piece of string?
Will I hit the lottery?
Where will the next lightning strike hit?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Shower door Caulking
Poboy
I need to seal the shower doors on my kids bathroom. I have recaulked it 2 or 3 times.:censored: Even removed the frame cleaned and resealed. But it keeps leaking.:surrender: These are the type with the aluminum frame and the bottom roller sits atop the tub. It keeps leaking between the tub and the aluminum door roller frame.
In your experience what is the best type of Caulking to use?
J_Walker
Florida
Poboy
use a piece of bicycle inner tube to create a gasket..
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Problem is it is nearly 60" across, and it does not screw down to the tub. So the sealant or Caulk is what holds/glues it down, along with some side pressure where it attaches to the uprights.
Poboy kartman
Poboy
I have always used DAP tub and tile caulk...(no caulk gun needed) and never had any issues. If the surface is clean it should be good for at least 10 years.
You might spray a little brake cleaner on a rag and wipe it down first. What did you use?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
We used dap tub and tile. That stuff in the red tube no caulk gun.
We fulley removed the frame scaped all the old crap off, cleaned it real well. Dried out the tub with a big fan for all day, then sealed it all and waited like 2 days to dry before anyone could shower. It ended up leaking worse than before. Now I need to do drywall repair too.
Have you heard of Something called VULKEM 116polyurethane sealant. I use it outdoors to seal furnace flue vent to flashings. It is some good stuff.
Poboy kartman
Not that exact polyurethane, but I have used polyurethane caulk in commercial applications for many years. Very tough stuff. A bit messy though, but if it doesn't work, you have a different problem than just caulking.
Any chance you could post up a pic or three of that bottom track and side rails?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Yeah That is some sticky messy stuff. and if it doesnt work it is h=ll to get off.
someones in there right now. maybe pics in a little while.
