anybody into rc stuff?
rocketkart
florida
so i pick up this boogie board up today at walmart for $13 what do you think?
robbie
Osceola, Missouri
I wonder if that board would dig into the water in a turn. There are fine points of rudder design that will encourage the boat to lean to the inside of a turn. It has to do with the angle of the rudder hinge line.
robbie
Osceola, Missouri
When you steer the boat into a left turn, will it lean to the right?
When you posted photos of your boat I did a google search and saw a discussion on an air boat forum where a guy was talking about the angle of the rudder post as well as the angle of the trailing edge of the rudder, and how these factors will affect the way the boat leans when turning.
I never thought of this stuff before.
Nor I- but thanks for bringing it up! I haven't done the rudders yet so it's not too late to "turn back" if you'll pardon the lousy pun. Seems to me, this could make the difference between one that steers nicely and one that digs in and flips. More homework required!
rocketkart
florida
so what would be the ideal setup for it? make the rudder setup lighter and less top heavy?
If I'm interpreting Robbie's post correctly, it's more of a matter of the "kingpin angle" of the rudder (to put it into terms we might better understand here) and the shape/angle of the back edge of the rudder. Since I have not yet researched this and have no further information, I'm just guessing here- but I can picture why...
robbie
Osceola, Missouri
Now that I'm reading the info it looks as if you would do OK with a single rectangular rudder, but you want to take care with the height. I like what they're saying about dual rudders arranged like an A frame. I'll probably do that when I get around to building an airboat.
My favorite part of this page is the guy's signature file: IF IT DONT RUN ON DRY GROUND
IT AINT A AIRBOAT!
rocketkart
florida
thats what i want to do RUN ON DRY GROUND. i do have a one man 6ft mini airboat that made with a 18hp opposed twin B&S engine the seat is like where you laydown on the boat like a gokart so its like riding a gokart throw the swamp its bad a$$. ill post some pics later.
rocketkart
florida
thats is awsome mr4ndre55. you should try a little smaller axle sprocket so it will take aff a little faster.
shakey0818
Do you have any more details on how to make this?I have 4 weed Wacker moters I. Would use.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
