moose
Can you make a quick sketch (by hand or in paint or whatever) with how you want the axle to work?
Welding a live axle together will be challenging... That same SKF page quoted a shaft straightness of something like +/- 0.25mm (over some length, maybe arbitrarily between two bearings)
If you are welding the whole thing together, you will need to sleeve it somehow. I would make the ID's of each shaft equal and use a plug (drill holes away from butt joint and fill with weld). This will add strength and move some stress away from the butt joint. A few more questions:
What are you going to weld with? (TIG/MIG?)
What is the longest you can turn center-center on the lathe?
Fabroman did bring up a point- turning the work at a higher rpm and moving tool at a slow feed should give you a nice smooth bearing surface. Match the tool and work speeds to the cutting speed that is recommended if you arent sure what to start at.
