anickode
So once I get the outlet installed, I should solder it in place. Is that what you're saying?
Absolutely. You can't thread a pipe fitting into 28 gauge metal and have it seal. Double up the metal in that spot and solder the pickup in. You can solder a brass bushing instead of a nipple if you prefer. Then you can thread in a nipple or a bowl separator or a shutoff valve.
And to answer the flux question, normal plumbing paste flux will work fine on tinplate.
