Alternate Gas Tank Options
JTSpeedDemon
2019 Build Off Winner!
Texas
:eek:!!!!!!!!
In USD that's still $100+!!! :eek:
I would love to go original style, but it's just soooooo expensive!
:eek:
Kentucky Boy
Bowling Green, KY
I once found a tank like that at an antique shop for $8. They can be found much cheaper than $100. Here it is on my Streaker before I re-did it. They are easy to mount.
anickode
S.E. Michigan
Shoot, an empty tin can and some lead solder will make a nice gas tank!
I've made them out of coffee cans, quart and gallon size solvent cans, etc. Use a can opener to remove the top from an empty can of PVC primer, and that's your filler neck and cap.
It does work well if you want a vintage look.
BigWes
Alabama
That would be awesome!
Do you have room for one Spunkwagon?
Or maybe if you can wait till after the holiday I can see about welding you something up...
But it would be a one off and might not be very pretty...but I would try and do it right.
I'd have to order a neck fitting and a fuel outlet.
Probably go simple.
I need ideas on what you want it to look like and time to do it.
---------- Post added at 08:08 AM ---------- Previous post was at 08:06 AM ----------
You know, a gallon size acetone can could be used like a rat tank like anickode stated above. Easy enough to do as well.
anickode
S.E. Michigan
Probably go simple.
I did a 3# coffee can from Costco. Still come in metal cans and I go through about 1 a month. Actually I used two cans. I cut the bottom out of a second one flattened out the lip and used it to cap the top of the first one. That I used the top of a PVC primer can, worked it to match the curve of the side of the coffee can, and soft-soldered it in place. Shined up a brass Barb fitting and soldered it in opposite the filler neck. Insta-gas tank. I made one with a 1 liter CHF can (euro spec brake/hydraulic fluid) as well, plus another from a gallon acetone can. I replaced the original can top with a piece of another can, and relocated the filler neck to the side so the tank laid flat.
JTSpeedDemon
Texas
Thats so expensive.........
How much is your predators.......
Cool story brahh...
From NR Racing, with shipping, a used P212 tank is ~$27.
As for the whole 212 brand new, $120 w/o coupon, and $100 /w coupon.
I assume you're asking because of CDN to USD?
---------- Post added at 08:28 AM ---------- Previous post was at 08:21 AM ----------
I just had an idea:
My dad puts a certain kind of brake fluid in his old Mercedes, and the cans the fluid comes in are a nice rectangular shape. I might be able to use a hacksaw and some soldering equipment to make it into a gas tank. I might even solder 2 cans together to make a bigger tank(I think ~2 liters), or I could rig up a Y fuel line fitting between them to have a normal use tank and a reserve tank! I'll see if I can get pics and drawings to help illustrate my idea.
---------- Post added at 08:30 AM ---------- Previous post was at 08:28 AM ----------
And of course, whatever tank I end up using, I'd paint it black.
---------- Post added at 08:44 AM ---------- Previous post was at 08:30 AM ----------
Probably go simple.
I probably do have room if you want to send me sumthin'. I just need a way to mount a tank more than anything. I need to get a good look at the seat back area today to get ideas, maybe make a test bracket.
anickode
S.E. Michigan
If it's a Mercedes it probably uses CHF fluid. This is a tank made from a CHF can, with a PVC primer top for the neck.
JTSpeedDemon
Texas
That's actually almost EXACTLY what I had in mind!
I'm thinking to make two of those, one for normal use and one for reserve.
But yeah, ^^ THAT is what I have in mind!
Staff Murderator
Bah! I think you need a tank that holds exactly one gallon o' juice, then you can do MPG tests.
What's the size (or capacity) of that tank you have, anickode?
anickode
S.E. Michigan
I would suggest cutting an extra piece of tinplate (about the size and shape of a fender washer) and soldering it to the bottom, then drill through that to solder in the pickup. Go karts rattle around a lot. The first tank I made for the rat wagon started leaking around the pickup bung from the vibration. Second layer sandwiched on there solved the problem
JTSpeedDemon
Texas
So once I get the outlet installed, I should solder it in place. Is that what you're saying?
Thats a cool can tank.....
With that can being galvanized...Did you use an acid(muriatic acid)for the soldering flux???
Staff Murderator
What about an ammo crate...
Crate? Yeah, that'll work.
..... I like beer too.
Is he even old enough to purchase ammunition in his state.......
Im guessing Dingo was talking about spam cans of surplus ammo???
Dingocat
Broke
NE Ohio
Box. Whatever it is. Good capacity and sturdy. And yes I know it's not green but that's how I got it.
