5HP + JohnDeere stx38
Thanx man, that second link you gave me, if I wanted to buy a centrifugal clutch, their R1200 that's quite a lot, and I need the ¾" bore, and I don't know if its got a keyway, and what does the "c/w" mean?
No problem. I know their clutches are expensive, but we live in good old SA where everything is imported, or if it is made here they charge import prices. I see that the one they are selling is a 3/4 bore clutch. They are keyed as well. I know, cos I have one.
c/w means that the clutch can only be run clockwise, which basically means that if you put the clutch on the engine, the pulley or sprocket will be facing away from the engine. cc/w, or counter-clockwise, means that you cun run the pulley or sprocket facing the engine. Some people call this running the clutch inboard or outboard.
I made a minibike using a 16T clutch that came from Checkmate Products. I bought it with a bunch of other things for R1000, so I scored. I needed to run the clutch inboard, or cc/w, so I called them up and they said I could turn it around if I want to. It will run fine.
You could also contact James Donavan at Max Torque and see if they will make one for you. I emailed him a little while ago, and even with postage they were cheaper than what you could get here. It is worth a try. He is really knowledgeable and ready to help. Here is the link with the details:
http://www.diygokarts.com/vb/showthread.php?t=13545&highlight=custom+clutch
You could also try a place from Grogro. They are based in Lynwood in Pretoria. You can contact them as well and see what they have. I have a torque converter if you are interested in buying it. Here is a link to some of the clutches they have:
http://www.grogro.co.za/Pages/ProductsPerCategory.aspx?ProductID=2
Here is a pic of the one that I have
IainBarnard
Boksburg South Africa
At grogro the 400 csc series is only R430, which is much better, but it only engages at 2200rpm, is that going to be ok? Or should I pay R200 more and buy a clutch with ajustable springs?, it would be nice to get a clutch, but until then I think I will use the belt cluch* how does a tourqe converter work, and how do I instal it?
A torque converter like mine is going to cost you over R2000 here in SA. I am willing to sell it for R1900 if you like. It has never been used.
I don't know much about the 400csc clutch, but engagement of the clutch at 2200rpm is a little high for karts I think, unless your governor has been removed. Let one of the other members maybe comment on engagement rpm's.
Here is a link to torque converters and how they work that might help you out
http://www.mfgsupply.com/gomini/gominiclutch/gominiclutchtorq.html
You will probably find that at the end of the day you will probably go for a clutch. The belt clutch, while doable, is sometimes a bit of a headache. I would go for it though if money is a problem.
Here is a pic of the torque converter that I have got
IainBarnard
Today I decided to build pedals for the kart* I used 1" x 1" square tubing and made it so that I don't need to stretch to compress the pedals. I also added a tension spring to that if I over press the brakes, I don't damage anything
IainBarnard
Sorry here's the images
Listen guys, any ideas on how to mount a keyed centrifugal clutch on a non keyed shaft??
I can't think of any way that you could do it. I wouldn't suggest it either because you want to keep your clutch as secure as possible on your shaft.
Wait for some of the other guys to reply as well. Maybe they have a better idea that what I have. If they don't, I am sure a boer sal n plan maak. :D
IainBarnard
I was thinking of maybe putting a pin through the shaft and the clutch
That would mean that you would have to drill through your shaft, which will weaken it considerably. Personally, I wouldn't do it. The last thing you want is things breaking apart at speed. I also cannot think of a good place to put a hole through the clutch either, unless you have a existing hole that would have been used for a set/grub screw.
You would also have to get the diameter of the pin as well as the holes perfect so that there is no play/movement between the clutch and shaft.
IainBarnard
Hey guys, I've decided to get myself a centrifugal clutch, but I need to mount the keyed clutch to the non-keyed shaft, I have two ideas, look at the pictures and tell my what you think, the arrows are where I weld*
jman231994
Australia
Im going to say this without a guarantee of my accuracy, haha. But I wouldnt weld to the crankshaft, all sorts of warping will happen from the heat and youll end up with some old hit and miss engine instead of your nice little subaru.
Its surprising that it doesnt have a keyway in it though. If you can find a cheap engineering/machine shop they could put one in for you, personally dont see why it would cost that much considering how simple it should be to do for them.
