Thanx man, that second link you gave me, if I wanted to buy a centrifugal clutch, their R1200 that's quite a lot, and I need the ¾" bore, and I don't know if its got a keyway, and what does the "c/w" mean?
No problem. I know their clutches are expensive, but we live in good old SA where everything is imported, or if it is made here they charge import prices. I see that the one they are selling is a 3/4 bore clutch. They are keyed as well. I know, cos I have one.
c/w means that the clutch can only be run clockwise, which basically means that if you put the clutch on the engine, the pulley or sprocket will be facing away from the engine. cc/w, or counter-clockwise, means that you cun run the pulley or sprocket facing the engine. Some people call this running the clutch inboard or outboard.
I made a minibike using a 16T clutch that came from Checkmate Products. I bought it with a bunch of other things for R1000, so I scored. I needed to run the clutch inboard, or cc/w, so I called them up and they said I could turn it around if I want to. It will run fine.
You could also contact James Donavan at Max Torque and see if they will make one for you. I emailed him a little while ago, and even with postage they were cheaper than what you could get here. It is worth a try. He is really knowledgeable and ready to help. Here is the link with the details:
http://www.diygokarts.com/vb/showthread.php?t=13545&highlight=custom+clutch
You could also try a place from Grogro. They are based in Lynwood in Pretoria. You can contact them as well and see what they have. I have a torque converter if you are interested in buying it. Here is a link to some of the clutches they have:
http://www.grogro.co.za/Pages/ProductsPerCategory.aspx?ProductID=2
Here is a pic of the one that I have
