5HP + JohnDeere stx38
IainBarnard
Boksburg South Africa
:wai:Hello all. I'm new here and this is my first post on the net. I am 17 and I'm doing this all by my self. No help from anyone. Anyway I have inherited a 5HP robin EY20 and it was in a bad state, I fixed it up and runs like a dream. The exhaust was rusted away so I had to "build" a new one and weld it onto the original flange. My father organised me a old JD stx38 body an wheels, nothing else besides the diff. Will be posting pics soon
IainBarnard
It was just a temp gas tank, it is only going to be there till I have removed the rust from the original gas tank. Well today I tried to find a way to mount the diff. Its meant to be run from a horisontal, so I just guess just turn it 90degrees so it runs from a horisontal engine via pullys, my clutch is going to be a belt slip clutch. To mount the diff I need to raise the carts body about 26cm to make space for the diff's body. I'm going to build a sub frame out of 1x1" square tubing and use flatbar as struts to absorb some shock. Btw my go kart has no suspenstion
IainBarnard
Well today went well. I scored some steel from school and started on the sub-frame* its going really well. The diff is mounted and the sub-frame is sub-welded. I need to reinforce the s-f and reweld my welds. Will be posting pics in 9hours. Need to sleep.
fowler
Bullsbrook West Aus
looking good
what do meen use flat bar as struts to absorb shock
id be carefull bolting straight though the box tube like that
it will flog out very fast with all that wieght
u need to fit some 10mm bar down each side to stop that
EDIT
also u will get better welds if u clean the rust and paint off first
IainBarnard
Looks really good! Keep up the good work!
Btw, how did you make the exhaust by yourself?
Well you need two tubes, pipes, or even square tubing. The inner tube is as big as my flange (diameter) and the outer tube is about 3times the inner tube. The inner tube has about 10 - 20 holes. The outer tube has 2 caps that seal the expansion chamber. Anyone correct me if I'm wrong*
That's similar to the construction of my homemade cherry bomb. However, I didn't have the patience to drill a million holes in the tube, so I used a thin kerf cutoff wheel in my grinder to cut slots instead. Your muffler looks great!
fowler
Bullsbrook West Aus
tryed that and drilled too many holes
may as well be straight though
and i used a fire extiquisher
yours looks like a proper one
nice
Fowler- did you put a "stop" in the middle of the tube? I did. Halfway along, I welded a solid slug in. The gasses hit the stop, and are forced out of the tube thru the slots and into the chamber. The gasses then get forced back in on the other side of the stop, and out the tailpipe. Did you put in a stop? How about yours, Iain?
IainBarnard
No sorry mate, no slug. I built a pistol silencer in the same way, so maybe that's why I don't have a slug. The muffler muffels quite nicely thou it does like to shoot 30cm flames once in a while,
IainBarnard
Well today I got quite a lot done* I got my steering done (whoop whoop). Yeah, I used and adapted the JD's steering to fit the kart, will post pics. I tried to visually design a frame/rollbar/look good thing, the pics are below*
Ps, why should I grind my welds?* in my mind, more metal = more strength?
Thanx man. Any idea where I can have a 120mm(diameter) pully made with 18mm threads?
Hey.... I didn't even see that you are from SA as well. Welcome!! There aren't too many of us here.
The only plave I can really think of that would make a pully for you would be a engineering shop. They might be pretty expensive though. You could also try places like Mcbeans.
http://www.mcbeans.co.za/contact.html
They might not have what you want, but they could point you in the right direction.
I hope you come right.
PS. I just reread your post about the grinding of welds, and if you are referring to the comment made by fowler, then he meant that if you clean all the rust and dirt off the surfaces before you weld you will get better results.
There are a couple of threads dealing with tension clutches. Have a look at these:
http://www.diygokarts.com/vb/showthread.php?t=14400&highlight=clutch+tensioner
http://www.diygokarts.com/vb/showthread.php?t=14082&highlight=clutch+tensioner
http://www.diygokarts.com/vb/showthread.php?t=5528&highlight=idler+clutch
Why don't you buy a centrifugal clutch that has a pulley on it instead of a sprocket? Like this for example:
http://www.mfgsupply.com/h34p3.html
http://www.checkmateproducts.co.za/price/price/Centrifugal_Clutch_&_Brake.html
The last link is a place called Checkmate Products in Brits. They make go karts and you can buy spares there
Edit: I was looking at your engine again. Has it got a tapered shaft. If it does, you will have to probably machine it down to a straight shaft, or use some adapter to make it straight. Or....you can get a new crank which has a straight shaft. That might be expensive though.
IainBarnard
Thanx man, that second link you gave me, if I wanted to buy a centrifugal clutch, their R1200 that's quite a lot, and I need the ¾" bore, and I don't know if its got a keyway, and what does the "c/w" mean?
