5 hp mods
wadebriggs
Are most of the mods for 5 hp motors only good for briggs. Or would they work with other motors like honda and craftsmen?
jr dragster T
Cold place
Well most honda's these day's are OHV. Which is another story from briggs flat head's. There's lot's of mods for both Brigg's and Honda's. But IIRC most craftsmen's are Tecumseh's and there's not too many mod's for those.
jr dragster T
Cold place
There not very expensive at all if you look around. You never know where you could find one. I'd look around at pawn shop's and garage sale's. Best place IMO.
kibble
I banned myself
No, don't think so. Around here the only thing I've seen is Postie trucks:
Kenny_McCormic
Kartless....
Michigan Troll
They dont use CT110's as postie bikes in US?
All of our postal work is done with modded/imported, right hand drive Jeep Cherokees (rural areas where your average 3 bedroom shack is bigger than the post office) or little custom USPS owned panel vans (for more populated areas, mostly S-10 parts). No motorcycles.
Kenny_McCormic
Kartless....
Michigan Troll
You buy them at harbor freight/tool sales/tractor supply/just about anywhere utility engines are sold. Should run around $100, HF usually has a sale/coupon running for $100.
then add a $100 billet flywheel(SAFETY FIRST!!!)
remove the governor
and a $40 header(only if the noise is acceptable where you live)
kibble
I banned myself
Isn't one of the mods people do, sticking a 3HP Briggs flywheel on a 5HP?
jr dragster T
Cold place
Russ the link you gave for that clone I have noticed some change's. Appears the filler neck on the fuel tank is a bit different. And it appears the fuel inlet is like 1/2 way from the top? Doesnt make sence?
jr dragster T
Cold place
And just adding a header and some jetting in a 6.5 clone will REALY make a difference!! Sounds awsome and realy pulls all the way through.
Russ2251
AZUSA:Powered by LAWN-BOY
Appears the filler neck on the fuel tank is a bit different.And it appears the fuel inlet is like 1/2 way from the top?
Yeah, cap used to be flush with top of tank. Perhaps an aid for less spillage???
Fuel pickup is still at bottom of tank. Maybe less chance of picking up sludge??? Curious.
