4 HP briggs and stratton
kibble
I banned myself
Yeah, kerosene is cool too, I just noticed that you have to work a little bit more to get it to loosen up stuff. The spray stuff usually dissolves stuff pretty quickly.
kibble
I banned myself
You'd be better off buying it at a store. It'd save you money.
tenlizard
do you think walmart will have it and how much would a store sell it for most likely?
kibble
I banned myself
Wally would probably have some and I don't think it should be more than $5. If you have kerosene, you should just use that though.
iwanttogofast
can i spray down my engine with the hose it's really dirty
if you plug all the holes and take the coil off the shroud and carb. we pressure washed engines in auto mechanics.
EDIT:Best if hot water is used. not all pressure washers can use hot water.
tenlizard
ok i washed down the engine with the hose on the flywheel. what was happening, is that there was dirt on it blocking the magnets from igniting the spark plug. i got it started now. now i want to remove the governor. can someone give me a link on how to remove a governor from a briggs and stratton engine. the governor makes the engine a 1 speed and i don't want that.
iwanttogofast
ummm its not hard just pop the side plate off and it will be like a plastic wheel just pull that out. also there is a wire that goes from it to the carb you need to unhook that but leave the piece that goes inside the block so you don't have a open hole. if you use the forum search im sure you can find some pictures.
jr dragster T
Cold place
The govener does NOT make the engine a single speed. The governer just limits the top RPM. and dont leave that governer arm in the engine. Bad things can happen. Use a bolt to plug that hole.
tenlizard
what about a lawnmower? it operates at a single speed. when you go from the driveway to the grass the lawnmower doesn't slow down because the governor has the engine to work harder to keep operating at that single speed
jr dragster T
Cold place
Thats because the governer is set up for WOT all the time. Grab the carb butterfly and it will idle. Meaning the motor IS capable or idling.
tenlizard
ok when i start the engine it thumps all over the place and is hazardous. is there a way to start the engine without it thumping all over the place? should i set it in the grass?
jr dragster T
Cold place
Maybe you should mount it to a kart and drive the thing? Lol sorry for the sarcasm. Just had to say it.:cheers2:
iwanttogofast
i drilled holes in the table i used to work on engines on and bolted them up to that. but don't take the gov off and do that with no load on it with a stock flywheel.
