280cc off-road shifter
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
A roll cage would be a good idea. Just dont forget that you'll need a seat belt.
Ive thought about making a trailer with an extra seat for my kart. Not sure how safe it would be.
Benjo
KRAZY KIWI
New Plymouth,Taranaki, New Zealand
here's some pics of my kart i drew up an idea on paint what do you guys think good/bad?
@Cam here's a closer at the back end, can bolt to the green and weld to the yellow
I'm not to sure about the seat on a trailer, doesn't sound to safe for the way i drive.
Rustydog2010
NZ Nutta :|
New Zealand
Whats the second picture? And at a guess 30 odd HP, sweet little buggy
Cam
Nz Petrolhead
Whangarei, New Zealand
10 or 12mm threaded holes there?
They look strong enough if you were to create a proper mount out of 4 or 6 mil plate
I don't mean go too fast with the seat plan.. but anyways, heres some sketch ups i did tonight -
1 inch pipe with a wall thickness of 3mm is incredibly strong, an added base support and plenty of space to mount your bolts, all you need to add to this is a plate on the top (which i could not draw in sketchup) with a large hole for the tow ball and your set.
Benjo
KRAZY KIWI
I'm going to get some more steel today (tubing and sheet) so that i can start making my roll cage and put a floor pan in, I'm getting all my steel for free :wai: thanks to my grandad, he has shed loads of it and he lets me have as much as i want.
Whats the best way to get surface rust of of sheet metal?
i think my handheld belt sander will do a good job.
Cam
Nz Petrolhead
Sew up a 5 pointer with old car seat belts, use designs from 5 point harnesses and then copy with car seat belts, we have done one for a go cart once, wreckers will probably let ya have some, just make sure they are sewed tightly with zigzag/crossover pattern.
