Not alot going on today with the hurricane hitting the East Coast, trip back to the auto parts store picked up a alternator ,also have a running 3 horsepower motor. Thinking maybe cool utility trailer ???
So handy, So versatile. Many people will buy 2 or 3 of the 10 dollar Harbor freight Models just keep from Changing "Blades", Wire Wheels, sanding Disc...
Gear ratio is 5.6:1 with a 20" tall rear tire and T-C. May be a little high on the final drive.
One way to find out. If it works you should have great top speed.
OSD of the 175 50 13 , is just under 18 " , I am over 200 lb , only looking for a top speed of around 35 mph ....................... "if it works " Chancer ??? what is your concern ?????
When using a Cent. clutch, geared at 6:1 the max tore size is 15" if you go to 18" or 20" tires you need a TC.
You have a TC but geared to 5.6:1.
My concern would be that it may be geared too High. In other words like trying to take off in 4th gear with a Stick shift car. It either wont move or it burns up Clutches.
