2016 - Hardcore build #1
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I believe that too!
hardcorewill
Sc
Hardcore 16
Nothing cool was ever built without shedding a little bit of blood.
hardcorewill
Sc
Hardcore 16
Taken more time than I thought it would .
hardcorewill
Sc
Hardcore 16
Sanded the tie rods down to bare metal hit him with a clear coat. Paint & primer on the foot pedals ,going with flat black.
hardcorewill
Sc
Hardcore 16
Steering wheel finished sanded to metal ,clear coated , going to leave it with the patina , give it a little Rat Rod look. Cut a piece of plexiglass for center cap and painted it to tie into the frame.
hardcorewill
Sc
Hardcore 16
just need brakes, and a throttle cable. before I can test-drive it.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
:thumbsup: Steering wheel came out nice!
The whole thing looks pretty "Hardcore" Good Job.
hardcorewill
Sc
Hardcore 16
Layed Back 4 life
hardcorewill
Sc
Hardcore 16
Back to the pipe bender to twist me up a custom header. Test out this Rustoleum High Heat.
hardcorewill
Sc
Hardcore 16
I think that's about big enough.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Have you driven this yet? I want to know how well that "swivel frame" works. I have never seen anybody try that before.
hardcorewill
Sc
Hardcore 16
Hopefully tomorrow or so I will get the GoPro, still need some reliable brakes.
---------- Post added at 09:08 PM ---------- Previous post was at 08:39 PM ----------
Wasn't sure about the swivel frame ,so I didn't finish grinding it. Seems to work real well ,will probably do better when I hit it with a grinder one more time. Before I tried it, I looked on the internet couldn't find where someone had tried it before. So if it works I'll call it the Hardcore swivel.
hardcorewill
Sc
Hardcore 16
Quarter ton spring welded with the swivel give it flexibility along with suspension. Just a thought.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I see that. But I think,
One direction the spring will be tensioning and the other un tensioning.
Does that make sense?
What do you think?
hardcorewill
Sc
Hardcore 16
I know you have seen the playground animals for kids to ride on Springs ,just my thought.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Oh now I get it.
I was thinking you would leave the swivel and just use a spring to "dampen" it.
hardcorewill
Sc
Hardcore 16
Slow day worked on the throttle cable. Drilled a hole in a small washer to hook to the gas pedal. Used a piece of copper tubing to hook the two cables together ,with the swivel frame I need a little extra play. Used a tornado strap for my connection to the engine.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Isn't that a 212 predator? There are factory connections for a remote throttle. Look between the air intake and fuel tank.
