Desertduler
- Messages
- 1,736
- Reaction score
- 13
Looking good! Boxing in the spindle brackets like you have keeps the king pin angle right where you set them and pretty much takes the flex out out the king pin bores, looks familiar. 15 degrees caster will permit you to use a steering wheel 20 degrees and you better have some strong arms or use handle bars like I do on my red flying pig but hey that sucker turns tight just how I like it. Also remember the longer your front axles are the more jacking effect will happen and the tougher it is to turn, I get away with my geometry because my front axles are short (less overhang) so if I were you I would tack everything together (like I did) first and set your steering up along with your rear axle and set your Ackermann steering (tacked also) and either have someone push or pull you on the kart and make sure that it turns easy enough with the steering wheel that you plan on using. Just my two cents.
Some of this should look Familiar to you.
