2016 - Beer Crate Racer (winner)
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Another little tip i found from a German Website.
On the plywood I will screw in place these L Brackets to hold the frame in Shape as I tack it.
Then I can leave the brackets in place and Flip the whole frame over and tack the other Side.
The Brackets make a sort of poor mans Frame Jig.
Also First I think I will draw a Center line and Even the entire Frame to scale, Directly on the wood. So I can line everthing up correctly as I tack.
Measure once, Grind, allign, measure again, Then Tack and Measure again.
Flip over repeat.
Lather, rinse, repeat.
Poboy kartman
Senior Moments Member
White Settlement Texas
Flip over repeat.
I don't know if you remember or not, but that's what I suggested when the subject of the OSB first came up; (establishing center lines and doing a complete layout to start with.) My recommendation was to do it before cutting the pieces though, so they could be checked immediately.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Clearly I did not remember. Or I would have given Credit.
I almost called it a "Poboy Jig" but that sounded Racist. So I changed it to Poor mans Frame Jig
LOL
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Tonights progress I got the frame all tacked, and I am happy with the results using the frame jig, and everything is square and Flat.
Also I forgot to mention this is all 1 1/8" .120 wall tube. A little heavy but I wanted it to be strong.
and the smaller crossbar is just there now as a place holder. Later it will be a support for the engine mount plate. Today it was just a tool.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Advice and Opinion
So i have these standard bearing mounts.
I could just weld them flat on top of the frame. (pic1) I did not think this was strong, but Kelly said it works.
Before I asked him, I had another idea.
To mount them on the side of the frame and weld on a support bar under them. (see Pics2and3)
What do you guys think?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Sorry I forgot this idea too: Duh it is my favorite. Weld a 1" vertical support behind the hangar.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Moving along nicely :thumbsup:. The vertical support does look good. It should be pretty strong. The only trick will be to get everything straight when welding
That seems to Always be the case! Especially with these Axle hangars. That was one of my main points to getting the Frame square in the first place. You need a good solid foundation to build anything.
With a square and a tape measure, and using the edge of the frame I think I will be ok. This will be the 4th axle hangars I have mounted. Dilligence paid off on the other 3:thumbsup:
Fortunately you can buy self centering bearings. I am not too sure if those that you have are self centering. So even if the hanger is slightly skew, the bearing can center itself with the ale
Desertduler
Looking good, I too like the vertical mount, I would use the axle to help jig the two bearings in place and you are using self centering bearings, the upright gussets would keep the bearing flange mounts from flexing during side loads, not telling you how to build your gussets but they can be sliced on an angle if you have the means from wide at the bottom where they will be welded to the top of the frame rail to narrow at the top to where they end flush with the top of the bearing mount hangers, this helps save weight and looks better too.
machinist@large
West Michigan, 49331
:iagree: :iagree: :iagree: Brett, I'd claim you were reading my mind, but your post beat me even logging in by about 10 hours or so.... :oops:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Thanks guys. Yes Landuse I was just remembering the same thing. They are self centering. I knew I could not have gotten that lucky previously. LOL
and thanks to Poboy, DD and Mac@lg.
I will use the upright supports.
And Brett I love that Idea of narrowing them at the top. I do have the means. Chopsaw and or Grinder.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
So Something like this:
again thanks for the input.:thumbsup:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I got the rear bearing mounts tacked to the frame. and test fit the Axle (no pic). Everything came out square.
I also cut the front end off and reset it. Something was off. I had to adjust (Grind) the front frame stubs. It is now square also, and the angles are correct. It is tipped back 22°. This is a little much, but I have calculated the frame Rake to be about 7° so I should end up with a final of 15°.
Also tacked on the Spindle brackets and made some little triangle gussets to box them in.
